Old Jan 17, 2015 | 11:45 AM
  #42371
Tweakin's Avatar
Nice shots...
Originally Posted by bmaloy32
Installed my first lift today with the help of some friends at the auto shop here on the base. Install went pretty smooth, taking around 5 hours. Installed the RK 2.5 Stock Mod with RK RRD 2.0 resi shocks all around and RK 3in bump stops front and rear. Also installed RK rear trac bar and rear sway bar links.
Went with some Method Race Wheels, Mesh 17x9 4.5 backspacing wrapped with some Kumho Road Venture MTs(35x12.5x17).
I am very happy with the way the install went and the ride of the lift shock combo.
Attachment 592280Attachment 592281Attachment 592282Attachment 592283
Old Jan 17, 2015 | 01:31 PM
  #42372
D_engel's Avatar
Originally Posted by MrChuckles
I don't mean to sound rude, but that looks pretty bad. I think it would look much better without the metal plate.
Nah, just some better hardware and it would be good. Some stainless button head screws would look good on there
Old Jan 17, 2015 | 02:05 PM
  #42373
brycesaunders3241's Avatar
Originally Posted by gsj8171
I copied someone on here by making a switch plate for my spot lights. This is the second time I made it. The first was with aluminum that was too flexible. This time I used an aluminum bar that I bought from home depot and made it long enough to add future switches if needed. I cut it with a metal blade hack saw and drilled it with a step drill bit from Harbor Freight. Then I filed and sanded it. I attached it with screws and nuts behind the dash. I like how it turned out for the most part but don't like the screw heads sticking out. I tried countersinking them but they are too close to the outside edge. Maybe I'll buy some rounded head screws. I also had a hell of a time pushing the switches into the faceplate. If you look close you can see the plastic tabs sticking out a bit on the tops of the switches. Is there a trick to them not sticking out? <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=592084"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=592085"/>
I think it looks pretty good!
Old Jan 17, 2015 | 02:14 PM
  #42374
TreyJK's Avatar
^ I kinda like it too!
Old Jan 17, 2015 | 05:35 PM
  #42375
AZ Honey Badger's Avatar
Finally finished up painting the hard top black. I had painted the T tops a couple months ago and put in the hothead headliners. I could not stand that god awful white interior.
ID:	592401   Click image for larger version
ID:	592402   Click image for larger version
Old Jan 17, 2015 | 06:17 PM
  #42376
espi's Avatar
What did you paint it with?
I personally like the white makes it feel more open and brighter than when my soft top is on.
Old Jan 17, 2015 | 06:36 PM
  #42377
Krylon flat black. And the white didn't work for me. My jeep is blacked out.
Old Jan 17, 2015 | 06:52 PM
  #42378
Chemlight's Avatar
Installed Metalcloak rear crawler bumper. Took about an hour and compliments the TeraFlex hinge nicely.
Sent from my Carl Gustav
Old Jan 17, 2015 | 07:03 PM
  #42379
GrapplerJK's Avatar
Vet Army
Looks GREAT!
Old Jan 17, 2015 | 09:22 PM
  #42380
ngillum's Avatar
Just got my smittybuilt fenders painted and put on.
