Old Jun 5, 2015 | 06:58 PM
  #43911
Cutman's Avatar
Originally Posted by lowendrider
I was well aware of the design differences. One of the first applications of the pentastar was the mini vans, therefore it too is a mini van engine.
He talks the talk.
Old Jun 6, 2015 | 02:48 AM
  #43912
Stephane87's Avatar
Originally Posted by 14Sport
If the sunshade doesn't collect water I would install it under the bows.
Old Jun 6, 2015 | 03:24 AM
  #43913
Stephane87's Avatar
Quick question before I do this, this week
I want to put a 2.5" lift (to replace my 1.75") on my JKU who already have 33" tires (Toyo Open Country AT2).
Can someone who have that set up, tell me the space in inches between the rear tires and bottom of fenders (in line with the center cap of the wheel) and also between the front tires and the bottom of fenders (in line with the center cap of the wheel)?
Thanks
*if the measures are from a stock jeep...even better
Old Jun 6, 2015 | 03:47 AM
  #43914
ccfewell's Avatar
Originally Posted by Stephane87
Quick question before I do this, this week I want to put a 2.5" lift (to replace my 1.75") on my JKU who already have 33" tires (Toyo Open Country AT2). Can someone who have that set up, tell me the space in inches between the rear tires and bottom of fenders (in line with the center cap of the wheel) and also between the front tires and the bottom of fenders (in line with the center cap of the wheel)? Thanks *if the measures are from a stock jeep...even better
Here are the measurements I took this morning. Running 285/75/17's on a 2012 JKU so basically a 34" tire. Front was 7 3/4" and rear was 7 1/2" to bottom of fender. Running a RK 2.5" stock mod lift. Hope this helps.
Old Jun 6, 2015 | 03:48 AM
  #43915
ccfewell's Avatar
Here is how I measured.
Old Jun 6, 2015 | 06:08 AM
  #43916
jkeleig's Avatar
Originally Posted by meep97
New wheels
Nice looking rig!!
Old Jun 6, 2015 | 06:28 AM
  #43917
jkeleig's Avatar
I forgot to mention in the "show your 33's" thread. I'm now running BFG T/A KO2's size 285/70r/17. They stock Goodyears measured 32.1" installed and these guys didn't give me much diameter at all. They measure 32.7 installed. Not quite a 33" tire. So it didn't add much to my height measurement. Click image for larger version
ID:	613816 Click image for larger version
ID:	613817 Click image for larger version
The last two photos are -front-then Rear- taken from center hub to fender bottom.
Old Jun 6, 2015 | 11:44 AM
  #43918
JK-Paul's Avatar
I found this helpful.
Metric Tire Conversion
Old Jun 6, 2015 | 12:22 PM
  #43919
Mbogan's Avatar
Finally got around to installing a PIAA dual Bass horn in my 2012 JKU. It took me awhile to figure out the best locations.
I removed the existing horn by washer fluid, reused the bracket, installed one in same location.
I tapped into existing wiring and ran wire on the right of compartment. I mounted under my Spod using existing nut and bracket.
Sounds much better!!!
Old Jun 6, 2015 | 01:15 PM
  #43920
reddenedbeard's Avatar
New shoes and a winch installed today..
ID:	613871   Click image for larger version
ID:	613872   Click image for larger version
ID:	613873   Click image for larger version
