Old Feb 12, 2020 | 04:24 AM
  #48521
Freedom21's Avatar
With 181,xxx miles on it. Some much needed love. Got a new Radiator, water pump/gasket, timing cover gasket, crank seal, PCV valve, Valve cover gaskets, oil pan gaskets, Transmission lines. Today it is getting TPS sensors installed and tires re-balanced. Also have an appointment pending parts arrival for the airbag recalls.
Old Feb 13, 2020 | 12:58 PM
  #48522
hornetman's Avatar
Veteran: Navy
Default Falcon Shock Skids
Right
Installed the easy bolt on Falcon skids, give me piece of mind so that I can prevent damage to shock
Old Feb 27, 2020 | 08:54 AM
  #48523
RedRubycon's Avatar
My wife got a magnetic phone mount for her car, and I really like it. Looking into the available options, though, I couldn't find anything that quite fit my wants for the Jeep... so I built my own. It's kind of a rough draft, and I had to cut a hole in my phone mount to get it to work the way I want, but so far it seems to be extremely functional. I'll probably pull it off and paint it and remount more elegantly one of these days so it doesn't look quite so stupid...
Old Feb 27, 2020 | 09:00 AM
  #48524
Freedom21's Avatar
Currently in getting the 3.73's replaced with 4.56's. Been living with the 3.73's running 33's and steel bumpers. But after adding the winch, cage, tire carrier, RTT and gear.... With all the added weight, it's time.
Old Feb 27, 2020 | 02:33 PM
  #48525
Carylab's Avatar
Default Lots of stuff!
Bought stock 2016 Sahara unlimited 2 weeks ago. This week put 6” lift, 22” Fuel Assaults w/37” tires, Bushwacker Flat flares, light bar, new nerf bars, Fab Fours Grumper grille and crash bar cover. In a couple weeks will put new rear bumper and tire carrier then start on new stereo. These things have the worse stereo I’ve ever heard!
Old Feb 28, 2020 | 07:40 AM
  #48526
icrashbikes's Avatar
Replaced a bad wheel bearing. The old one was suuuuper crunchy.
Old Feb 28, 2020 | 09:38 AM
  #48527
08RescueGreen's Avatar
Vet Army
Added oracle LED head and fog lights. Easy hour and now it looks so much better!
Old Mar 2, 2020 | 11:17 AM
  #48528
RedRubycon's Avatar
Installed my Quadratech flashlight mount
Works like a treat so far! Little concerned about it being bolted to some relatively flimsy plastic trim, but will see how it holds up.
Installed a Bluetooth receiver for the stock stereo so I can listen to music more easily
It's spliced into the dash's 12v outlet so it turns on/off with the key and mounted just inches from where my phone sits on its mount
Just a nice flat 90 degree aux cable is the only evidence that something is up. Works great with the Bluetooth receiver so far.
Installed some Rugged Ridge hard-mount grab handles
Really wish I'd added these sooner; they make getting in and out a lot easier.
Old Mar 4, 2020 | 02:27 PM
  #48529
GreenJK07's Avatar
Removed my on board air setup from the back of my Jeep and made a mount to transplant to my trailer. More space now for gear 😁.
ID:	677513   Click image for larger version
Old Mar 5, 2020 | 12:42 PM
  #48530
ctopher86's Avatar
Vet Army
Added a new Digital Streaming DVR Rear View Mirror so I can have some piece of mind when backing her up.
