Old Jan 1, 2010 | 08:53 AM
  #7371
KrasnayaZnamya's Avatar
Changed my plugs for the first time...what a pain in the arsch!! I took the advice of someone on this forum and started with the worst (passenger rear plug) and by the time I got to the driver's side, it was my reward.
Every plug was gapped different and was a slightly different color...put in some E3's, noticed a definite better throttle response, but I'm not sure I'd attribute that to the E3's or to the fact that I simply have plugs all gapped the same now...time will tell!
Old Jan 5, 2010 | 11:37 AM
  #7372
Jeep Hound's Avatar
Default Smittybuilt Tire Carrier Mod
My friend and I took a day to weld a Gerry can holder and toolbox holder to my Smittybuilt tire carrier.
The Tool box is an ammo box that was used to carry 5.56mm chain link rounds. Gerry can is a CDN military 20L gas can
Old Jan 5, 2010 | 11:43 AM
  #7373
Xtreme545's Avatar
Originally Posted by judas
cleaned it finally, also got my new spare in and mounted.
not sure why they look way bigger mounted on the spare carrier...
oh thats because the tards sent me a 10" rim instead of the 8" i paid for. ORO plate holder/light will be here tuesday.
also removed all the stickers. as soon as someone will sell me some used 2dr rubi rails i'll put a project jk.com sticker on there.
and of course had to add a sticker with my motto on it.
Did you just remove the factory rear bumper?
Old Jan 5, 2010 | 11:46 AM
  #7374
4whelin's Avatar
The XRC bumper additions look badass!!! Great job!!
Old Jan 6, 2010 | 08:40 AM
  #7375
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
Finally had time to get the ARR Radio Bar installed.
Now all I gotta do is get the radio installed and Ill be a happy Jeeper.
Also got the Dirty Dog sunscreen installed.
Name:	ARR Radio Bar.jpg
Old Jan 6, 2010 | 11:25 AM
  #7376
sm_rubi's Avatar
Sweet! Thanks for sharing...I'll have to look into the bar, are the wires all run through it? Currently mine is mounted on the header but I'd like to mount it some other way.
Old Jan 6, 2010 | 11:37 AM
  #7377
donnie's Avatar
On mine, its bolted onto the header bar.
Removed the Freedom Top, drilled the mount holes and replaced the top.
And yes the wiring does run thru the inside of the bar itself.
It has a hole in the middle to run the wires out for the radio.
Kit includes everything to install it. Bolts, wiring, fuse, and instructions.
Hope this helps.
Old Jan 6, 2010 | 12:53 PM
  #7378
HG07JKRubi's Avatar
Originally Posted by Josephus
This week I got some bigger tires & a lift.
2.5" TeraFlex coils and Shocks
35x12.5 Mickey Thompson MTZ
Here is a picture showing the increased wheel travel. As noted by others, the brake lines are the limiting factor in the front.
Overall I am happy with the ride quality, and braking distance is dramatically improved with the MTZ's....hang on to your teeth - wow.
Nice Josephus !!! Congrats.
Old Jan 6, 2010 | 01:02 PM
  #7379
fadeout's Avatar
Washed all of the road salt off of it that's been building up since before the holidays. As I was doing this the runoff water was turning to ice
Old Jan 6, 2010 | 02:51 PM
  #7380
zook's Avatar
I did the same thing tonight, It was 24 out.
