2010 jeep recall due to fires!!
Old May 20, 2012 | 07:08 AM
fstopme's Avatar
Default 2010 jeep recall due to fires!!
Fire risk prompts recall of nearly 87,000 Jeeps (click the link.)
Old May 20, 2012 | 07:56 AM
RKracing's Avatar
Originally Posted by fstopme
CLICK BELOW LINK........
https://www.jk-forum.com/forums/jk-t...answer-232665/
Old May 20, 2012 | 01:01 PM
JKJA10's Avatar
Thanks for the info.
Old May 20, 2012 | 03:30 PM
Four Low's Avatar
Thumbs down Red Herring
So where's the recall for the overheating issue with the automatic due to inadequate cooling? This "recall" removes the auto tranny skidplate because of the risk of debris getting wedged, catching fire from converter heat. Leaves the rock- grabber bar. Typical corporate response to a problem. Ignore; deny ; perform a 15 minute " fix " that leads to other problems. Thank you, Chrysler.
Old May 20, 2012 | 08:21 PM
snytribe's Avatar
There way to fix is.... We list a skid plate. What's with that?
Old May 20, 2012 | 08:24 PM
snytribe's Avatar
Sorry dam phone. Ment we lose a skid plate. This makes no sense at all. Maybe they can also fix a leaking roof by removing it and putting in a bar.
Old May 21, 2012 | 04:48 AM
ridelots24's Avatar
x2 ! ! !
I dropped this skid plate when i installed the AEV 3½" lift - since it limited travel of the drive shaft. I've been looking for this recall and was hoping it was going to be the transmission cooler fix.
Old May 21, 2012 | 10:44 AM
JK-jeepit's Avatar
Have a 2011, and the Trannsmission skid bar was replaced with the Hard Rock Oil pan/Tranny/catalyic convertor skid....
so I guess I'm a fire wating to happen...
Old Jun 14, 2012 | 03:32 PM
brutalvette's Avatar
I logged in and checked my build sheet and listed transmission skid bar instead of plate so you can check that out to see if you are affected.
Old Jul 23, 2012 | 02:16 PM
Hvacwelder's Avatar
I just received the recall notice today, dealer says it's like a T bar. I'll know by this Sat, how it looks and acts.
