Another dreaded Gas Mileage Thread
Old Sep 29, 2010 | 10:43 AM
  #21
spartan99's Avatar
Originally Posted by jmat1980
You seem to be the biggest troll around...if you don't like th site, or the people here, why not go elsewhere?
Sent from my T-Mobile G1 using Tapatalk
Once again you post something on someone else's thread that has nothing to do with the topic. I offered information regarding the topic, troll.
Old Sep 29, 2010 | 11:34 AM
  #22
jknit's Avatar
still haven't had much in the way of real answers here guys
Old Sep 29, 2010 | 11:49 AM
  #23
GoodysGotaCuda's Avatar
Originally Posted by GoodysGotaCuda
You will never average 19.5mpg with a 3.8L in a lifted JK. Probably never 18mpg, maybe 17 if you lucky with the mods. It's just not in the cards, unless the moons align for you. Aerodynamics is brutal on this, lift it 4"...even worse. Combine that with a small engine and it's just not in the cards.
If someone says their 4" lifted 4dr gets higher than 17 on average, I'm impressed! Is EVERYONE actually calculating their milage? My display says 18-20 and I get 16ish on paper...
Thought I gave a little info, pretty much the mods and the vehicle will never get 2-4mpg over what you are currently getting. Don't expect the "engine break in" either. In my opinion..
Old Sep 29, 2010 | 12:33 PM
  #24
spartan99's Avatar
x2.
Jknit, everything in this thread pretty well sums it up. Lifts, tires, etc. wipe out mpg's big time. Drive carefully and you'll get around 18+ or -. The second you mash that pedal, your mpg's get wiped out big time. 18mpg's is achieved by driving very conservatively.
Oh, and no mod will improve your mpg's except for the flashpaq, apparently. There's controversy about tbs's, intakes, exhausts, etc., but it seems as though there's no controversy on the flashpaq. It seems everyone who has one agrees that there is a noticeable gain in mpg's with it.
Old Oct 2, 2010 | 02:33 PM
  #25
windycityjeep's Avatar
36 miles to the gallon-------OK now that I got your attention, 2008 Sahara stock--the display tells me I average about 19.5 to 21.5 combinmed city and highway and I drive like an old lady all the time.
Old Oct 2, 2010 | 03:57 PM
  #26
tpm152's Avatar
I can tell you that I upgraded all of my fluids to Royal Purple it had a much larger impact on power and MPG compared to the MBRP cat-back. Many may point out that the Synchromax doesn't comply by the Chrysler standard for the manual transmission fluid and transfer case (ATF+4) fluid. But I can say that I have been running it without a problem for over 20K miles at this point and when I swapped all of my fluids from stock fluids to royal purple (6-speed and transfer case to Sychromax, front and rear differential to Royal Purple 75W-90 and the engine oil to their synthetic 5W-20) I picked up 1-2 mpg and definitely some usable low RPM (1000-2000 RPM) torque/power.
I have a hill I had to climb on a regular basis. Before the swap I had to downshift to 4th gear to climb it to keep the RPMs over 1000. After the swap to all RP fluids, I was able to leave it in 5th all the way to the top of the hill and the RPMs didn't drop below ~1100 RPM.
HOWEVER, I won't advise against the MBRP exhaust. Though I didn't see any noticeable MPG increase the sound is -definitely- worth it. It is a nice noticeable low rumble but isn't loud enough that it gets annoying or that the neighbors complain. Plus I had a slow rear-end collision a little while ago and the other car just slid under the back of the Jeep and didn't hit the exhaust or anything because the off-road version tucked everything up out of the way (and paid for itself by not needing replaced!)
Hope this helps!
Old Oct 3, 2010 | 05:06 AM
  #27
Lucas718's Avatar
Originally Posted by pcarpenter
I'm just waiting for the all the hammerheads on this forum to start posting their claims of 20+ mpg.
Guess I'm a hammerhead then. Since I started keeping track back in February, I've averaged 21.1 mpg over 22 fill-ups covering about 8300 miles.
My Jeep is not lifted.
Old Oct 3, 2010 | 06:15 AM
  #28
Default Got Gas Running Out Of My Ears.
With 35" Toyo's, 4.88 Gears, and Superchip after 2550 miles my display says:
99.18
