Can't decide on a hard top hoist
Old Jul 5, 2015 | 06:33 AM
bigblue506's Avatar
Default Can't decide on a hard top hoist
Cannot decide on a hard top hoist. I have a 15 JKU. I cannot decide if I should buy a hoist or build my own. What brand or model? What type of lift? Motor, crank, rope with pully? Any help here would be appreciated.
Old Jul 5, 2015 | 09:38 AM
71Luber's Avatar
Harken hoister
Old Jul 5, 2015 | 04:01 PM
bigblue506's Avatar
Originally Posted by 71Luber
Harken hoister
Why the harken over the others? How was install?
Old Jul 9, 2015 | 04:08 AM
71Luber's Avatar
Price, ease of use and overall quality
Old Jul 9, 2015 | 07:01 AM
Dodge4me's Avatar
By the time i was done with my DIY hoist with a harbor Freight hand crank trailer winch, I think I was into it about as much as the cheapest hoist on the market, but mine was much more stout!
With any ceiling mounted hoist, though, you want to make sure you are through bolted into whatever support you use and not rely on only a lag bolt eyelet.
Old Jul 9, 2015 | 07:27 AM
mcochrun13's Avatar
Do a search on the forum for "Racor". It's not advertised as a hardtop lift, but I have been using it for a few years now and it also gives you a place to put the front sections too. Plus you can use it manually or powered with a 1/2 drill driver. I can have my top off in under 15 minutes from start to finish.
Old Jul 10, 2015 | 09:05 AM
Sahara Lee's Avatar
I really like my Harken Hoister. I prefer the feel and control of manually raising and lowering the top over using an electric winch.
https://www.youtube.com/watch?v=eUheHz-DuPg
ID:	617422   Click image for larger version
Old Jul 10, 2015 | 12:02 PM
MavisJk's Avatar
I use two ratchet straps and two pull straps. four eye bolts in studs in the ceiling of the garage. ratchet it up and use the pull straps and tension to lower it back down. The top weighs maybe 150 lbs at the so each strap holds about 40 lbs each. Plenty of strength.
Old Jul 10, 2015 | 01:06 PM
2BAJeep's Avatar
Can you post some pics?
Old Jul 10, 2015 | 02:58 PM
The Whale's Avatar
I bought the Harken. It's a little pricey for what you get but all the pieces were there and harken hardware is top quality. The hoist works great and I use it all the time.
