Check the Status of your Jeep JK Wrangler - Order Status Codes
Old Feb 5, 2007 | 02:46 PM
  #801
mikesjeep's Avatar
Default hardtop and Mygig allocation
From Jeff, Don a Vee
"Allocation is out today for dealers. Hard Top Unlimiteds and anything with MyGig is on restriction for March (Built Out).
If you are already in D status before today you have nothing to worry about."
Hi Jeff,
When I called my dealer today he didn't mention anything about allocation restriction with mygig or the hardtop. Is your information on the web for us or just an internal message?
Thanks
Mike in Seal Beach
Old Feb 5, 2007 | 02:56 PM
  #802
JPRS51's Avatar
Hi Jeff,
Thanks
Mike in Seal Beach
The information about the MyGig restrictiona nd the Hard Top on Unlimited restriction is nation wide. So if one of those items is on your order and you have not yet been moved to D status you will probably not have the opportunity to move to D until the allocation period in March (for April build dates).
Old Feb 5, 2007 | 02:59 PM
  #803
csims723's Avatar
Default Moved up to BX yesterday
Well I finally moved up to BX status on 2-5-07. Guess the Hardtop issue is almost worked out. At least this is what I wanna believe. Chris
Old Feb 5, 2007 | 03:28 PM
  #804
4Down's Avatar
Default When do 2008's start being built?
Jeff, do you know when they will start building the 2008's? If April is the earliest build date I would rather wait for a 2008 if I could get it in August. Just asking. Thanks.
Old Feb 5, 2007 | 04:55 PM
  #805
JPRS51's Avatar
You should be able to order the 2008 models in late July to early August. They should arrive in early to mid September.
Old Feb 5, 2007 | 05:06 PM
  #806
billycj7's Avatar
Jeff, I ordered a 2 door rubi with mygig and hardtop........So does this mean that I'll be waiting a long time for my Jeep? I just went to bk status today.
Old Feb 5, 2007 | 05:30 PM
  #807
4Down's Avatar
Thank you Jeff.
Old Feb 5, 2007 | 06:21 PM
  #808
RedRockJK's Avatar
Mine is finally on a train!
Old Feb 5, 2007 | 06:50 PM
  #809
RedRockJK's Avatar
Also, not to scare anyone, but one of the Rail companies that Chrysler uses had a derailment on Feb 4th in Sadorus, IL., blocking the main track on the corridor between Decatur, Ill., and Ft. Wayne, Ind. Hopefully noones 07 Wrangler was on there!
http://www.nscorp.com/nscorp/applica...ert020407.html
Old Feb 6, 2007 | 08:18 AM
  #810
JPRS51's Avatar
The hard top is not an issue as of yet. The MyGig will hold you up for a month. your next chance at moving to D will be on the 1st Monday of March.
