EMERGENCY!!! Please read!!
yeah definately sounds like fuel delivery problem, how deep was the water and did it go up to the gas cap? How aobut the evap canister was it damaged or ripped off? I know someone on here had theirs ripped off and the fuel tank sucked in alot of mudd and water.
How does it sound when it runs for the cpl seconds? After you try cranking it without using the starter fluid check the spark plugs to see if they are wet from fuel. Did anything come out of the plug holes when you first took them out? How wet was your filter/air box?
I don't know if there is a fuel shut off switch or not but if the fuel pump is running that doesn't appear to be the cause for it not firing on its own.
My guess is that the mass air flow sensor may have been damaged if water did inter the intake. There are a couple different styles of MAF sensors used today but I don't know what the 3.8L JK uses. A few of the styles out use a fine gauge wire as part of the sensor that may have broke (replacement required to fix). This would cause the ECU to believe that there is no air flow entering the intake thus ECU does not inject fuel into the cylinders.
This is where technology can really bite you in the ass! Best of luck to you on getting that thing running!
WHAT IS HIS FUEL GAUGE READ "FULL / M/T"
and no - no cut off s/w man i know that he is going to get a toung lashing when he gets home //// the ever famous "DAMMIT I TOLD YOU"
here's what i've done & it STILL WON'T RUN. it will start with starting fluid, but not stay running.
i did:
pulled plugs, cranked VERY shortly twice to blow out any water/debris
oil change and filter
air box/filter removed
seems all electrical connections are water tight. the few i pulled apart to check were clean & dry.
IS THERE A FUEL SHUT-OFF SWITCH????? any other type switch tp prevent starting???
there must be something silly that i don't know about preventing it from starting. the fuel pump runs when the ignition is switched on. the plugs looked good. i bought two sets b/c the guy didn't have the newest book and neither set was the right one. what else can it be? i am stuck here in IN. luckily the hotel had one room left, or i'd be camping in my jeep.
thank you for all your advice so far, much appreciated. any more help to get me home would be awesome.
thank you!
i did:
thank you!
i checked everything that i could think of. no damage appears to be done to the EVAP canister. wires are in tact on it also. pulled a O2 sensor off, doesn't seem like there's water in the exhaust.
there are two lights that stay on when i attempt to start the jk, the engine light and the lightning bolt/throttle body light.
the negative battery terminal was disconnected several times for long periods, plus all the other things: oil change, blew out spark plugs, used MAF cleaner spray on MAF.
I CAN'T SEE ANY DAMGE TO ANYTHING UNDER THE HOOD OR ELSEWHERE. all wires are connected, to the best of my knowledge. thank you for all help. i'm leaving the hotel so my wife will be reading this back to me. please include details, big or small if you have any more advice for me. if not, send money donations to Attica , IN or someone find me a job 'round here
thanx ALL
thanx ALL
