Found a great sale on a 4" lift!
Old Mar 24, 2009 | 05:46 PM
wolfosJK's Avatar
Talking Found a great sale on a 4" lift!
Well, I broke down and decided to go with Zone Offroad's 4" lift for the 4door. If you look on pg 92 of the April issue of JP magazine, there's a sale going on and i was able to get the lift for $459.95 instead of the regular $575.99! It comes with the shocks and adjustable trackbar so i'm pretty happy! It should be coming in next Monday so we'll see when i can get it on!
Old Mar 24, 2009 | 05:52 PM
bigbluejk's Avatar
I was on a trail ide with someone that had their 3" and liked it. Seemed to work well for him. Congrats, make sure you ke photos.
Old Mar 24, 2009 | 05:53 PM
mudslingin44's Avatar
i seen it too,good luck with the kit and post some pictures when it is installed
Old Mar 24, 2009 | 06:13 PM
wayoflife's Avatar
JK-Forum Founder
4" of lift is a lot of lift especially for a kit that comes so incomplete. so you know, you really should ditch the cam bolts that come with this kit and start looking to get a set of adjustable front lower control arms to set your caster. also, you really should pick up a front track bar drop bracket and a dropped pitman arm as without them, your handling will suck on the highway. another thing you really need to be thinking about is drive shafts. if you have an automatic, you will need to get a new u-joint style front shaft and if you have a 2-door, you will need to get a new rear shaft and adjustable upper control arms to set your pinion angle.
i realize that a lot of people are drawn to how cheap this kit is but it really is because it doesn't even come with the minimum amount of components that a 4" lift should come with. please do yourself a favor and be sure to pick up the other items mentioned as they will help your ON ROAD ride and handling to be better.
Old Mar 24, 2009 | 06:22 PM
slowpokie's Avatar
Default 4"zone lift
Thanks for the heads up. I was going to order one of these
Old Mar 25, 2009 | 08:25 AM
wolfosJK's Avatar
Thanks for the info, my last wrangler was a YJ so I'm still getting used to everything involved with this coil spring suspension. I didnt think of the dropped pitman arm or trackbar bracket, what brand, etc. would you guys recommend?
Old Mar 25, 2009 | 08:53 AM
TeraFlex's Avatar
Sponsoring Manufacturer
#1600440
Old Mar 25, 2009 | 08:54 AM
wayoflife's Avatar
JK-Forum Founder
yeah, unlike your YJ with leaf springs, the JK is a totally different animal.
regarding dropped pitman arms, they are all made by the same manufacturer so it really doesn't matter who's you get but you WILL need to make sure and run it in conjunction to a track bar relocation bracket. i am running a full traction drop bracket and it is a direct bolt on application. currie make a very nice bracket as well that attaches to the axle mount but it will require welding. teraflex makes a great bracket as well with a brace but it requires welding as well.
the other thing that i would highly recommend is the adjustable front lower control arms. the kit you got comes with cam bolts but these are a terrible solution for adjusting your caster. and again, if you have a 2-door, you really do need to get a set of adjustable rear upper control arms as at 4" of lift, your factory drive shaft will go out sooner than later and will need to be replaced with a double cardin u-joint style shaft. also, i know your kit comes with brake line extension brackets but at 4" of lift, you really should be looking at a set of extended brakelines instead.
Old Mar 28, 2009 | 06:44 PM
wolfosJK's Avatar
Would this work for the trackbar bracket? looks like its a bolt-on too!
http://cgi.ebay.com/ebaymotors/07-09-JEEP-JK-WRANGLER-RUBICON-EXPRESS-TRAC-BAR-BRACKET_W0QQcmdZViewItemQQcategoryZ33587QQihZ011QQ itemZ320354003821QQrdZ1QQsspagenameZWDVW
Last edited by Robar; Mar 28, 2009 at 07:25 PM. Reason: PLEASE DO NOT POST DIRECT EBAY LINKS
Old Mar 28, 2009 | 06:57 PM
JKJosh's Avatar
I have had the 3 inch kit since August and couldnt be happier with it. I am sure you will be just as happy. They have great customer service too.
