oil pan f'd! anyone replaced one yet?
#32
JackMac knocked his on a trip a month ago and had to replace the oil pan... I think it was over $150, but in his case it affected the draincock. If yours isn't deformed to the point where it impacts draining the oil, you might be OK
#33
Moparpartsamerica dot com has them for about 129.00. It shows that you can just get the lower pan section alone but after ordering they emailed saying you had to get both parts.
#34
The oil pan and gasket cost about 180 with tax and all. Although I haven't replaced it yet and have put about 3000 miles(!) on it since it happened without issue. I'm still going to replace it, but as far as running - I think it runs fine. The only reason I'm going to fix it is because I won't go offroading until I do -- I'm too afraid of punching through the fragile steel.
And moparpartsamerica does not sell just the lower - I already tried that. It is only available as a kit.
#35
