Picking nits
Old 07-10-2010, 05:00 PM
jkforum96's Avatar
Default Picking nits
First let me say that I have over 15 years and 200k miles of jeep ownership. Secondly I think the 2010 JKU is an abso-4reakin-lutely amazing vehicle.
That said, what are some of the 'WTF were they thinking' nit picks on the JK. You know, small things things that make you nuts. I will start with 2.
1)The waterfall I have to navigate every time I get in or out when it's raining. There is no gutter above the door on the soft top and Niagara falls when it rains. Someone noticed this because newer 2010 JK's have little fins molded on the rubber seal above the windshield. Their apparent purpose is to channel the water down the A pillar. I do not know if they work. I can not believe no one identified the waterfall as a problem during the original design and testing.
2) If the tailgate is closed when I drop the soft top the 2 tiny screws holding the CMBL nicks the leading edge of the front of the top. The tolerance is so close that the top material is only nicked, not ripped thru. After adding the back doors and all the rear cargo space the designers came about a millimeter short of the top clearing the 2 screws.
Does anyone else know what I'm talking about?
Share your nit pick. You will feel better, I do.
Old 07-10-2010, 05:38 PM
azxr's Avatar
The plastic piece that holds the transfer case cable to the transfer case.
Old 07-10-2010, 06:37 PM
wcfd111's Avatar
I'm guessing yours broke too and now your stuck in 2WD... I noticed mine broke when I went through a intersection at 30 MPH and then i saw my shifter for 4WD move. thats when I noticed that it was all Floppy and that the cable had disconnected from the transfer case... still waiting on parts
Old 07-11-2010, 05:41 PM
JPSquad's Avatar
I really like how they put the evap can in a open spot, just waiting for rocks to rip it off.
Old 07-11-2010, 05:58 PM
rich1340's Avatar
All of these are good ones...
What were they thinking... A vehicle, for the last 70 years, has been made for the doors to come off.. DO AND THEY PUT THE F$%^ING MIRRORS ON THE DOORS!!!!
Old 07-12-2010, 04:41 AM
JeepaRoo's Avatar
how about maybe headlights that you can actually see something?
in this day and age of computers in the jeep cant they detect the doors are off and shut down the radio when you turn off the jeep?
on the 2 door why did they get rid of the tilt release passenger seat that worked so well on the TJs..
-Christopher
Old 07-13-2010, 07:42 PM
pastorsteve's Avatar
You can eliminate your waterfall in about 20 minutes with the Top Prop.
Old 07-13-2010, 08:23 PM
Widewing's Avatar
I bought a Top Prop, and was completely disappointed....
$6 in marine batten sockets, a $5 piece of fiberglass and four 50 cent hose clamps for $40.... Cheap junk, clearly designed by a boat owner.
I bought a 12" length of 1.5" x 1.5" steel angle stock and made my own mounting that allows me to snap it in between the bars right over the padding without cutting away the foam padding or using the butt-ugly sockets and hose clamps. Comes off in two seconds...
Old 07-13-2010, 08:28 PM
DARB's Avatar
What about the missing "fold and tumble" front passenger seat?? Rear access is impossible unless your between the ages of 3 and 11.
Oh... and seat belt tensioners?? what happened to those????
Anyone with any ideas or products to solve these two would be great!
Old 07-13-2010, 08:58 PM
Hellbound13's Avatar
The Mickey Mouse non-greaseable tie rod ends/ plastic lined ball joints.
The Tinker Toy steering shaft.
Quick Reply: Picking nits
