Voltage leak questions.
My battery will not hold a charge and I think I have a voltage leak. Any help would be appreciated as I am no expert in diagnosing electrical issues, but I am eager to learn.
I removed the ground cable from the negative battery post, and am completing the circuit with my multimeter by connecting one lead to the detached ground cable and the other lead to the negative battery post.
With my multimeter set on ohms, I get a reading of either 6.75. Is 6.75 normal? I figure there must be some draw with a computer, clock, etc. Or shoukd it be 0?
2008 JKUX no power anything no cruise control nothing but the base model.
Thanks in advance you folks are always very helpful.
Dumb question, but did you get your battery tested? A bad battery is surely a likely cause. At rest, the voltage on your battery should be around 12.6 - 12.8. While running it should be around 14. You need to take your battery to an auto parts store and have it load tested. They do it for free. I've never heard of doing and ohms test on a battery. A multimeter applies about 5 volts on the leads when testing for ohm. So you are taking a 5 volt supply and touching it to a 12.6 volt supply. Makes no sense to me.
Instead of ohms, when you disconnected the neg terminal you could have put your meter into ammeter mode and measured the current flowing. Though I don't know what a "good" reading would be for that.
Thanks. The battery is only a few years old so I haven't checked it yet. I'll try that next. I don't have an amp section on my mm. Just volts and ohms. I guess I need a better mm.
This was so helpful.
https://www.jk-forum.com/forums/jk-e...aining-333220/
... I am no expert in diagnosing electrical issues ...
With my multimeter set on ohms ...l.
According to Ronjenx, a good reading is 5-35 milliamps.
"Normal drain of a JK that has gone to sleep is from five to thirty-five milliamperes.
It takes about 5 minutes for all the computers to shut down after the ignition switch is turned to OFF.
Disconnect the battery negative cable and place the leads of an ammeter between the cable and the battery terminal. Wait 5 minutes and note the draw. Make sure not to lose continuity. If you do, the 5 minutes starts over when you reestablish continuity.
If you see more than the normal five to thirty-five milliamperes, start pulling fuses and reinstalling fuses, one at a time. If one causes a significant reduction in the amp reading, that's the circuit you need to look at.
If no fuse shows a reduction, pull the alternator lead and see if that shows a reduction."
