Stock jku rubicon on the rubicon?
Old Nov 3, 2012 | 03:37 AM
htweelz's Avatar
These guys didn't seem to have any problem.
http://www.youtube.com/watch?v=vov-IPy_6NM
Old Nov 3, 2012 | 07:45 AM
familytime's Avatar
JK Forum Regional Rep
Also when was this video taken?Alot has changed since then.A stock jeep with a good spotter can do it.The Rubicon trail still has areas that will still test you and your rig,while other parts may not
Old Nov 3, 2012 | 09:56 AM
Stuka's Avatar
Lot has changed in the last 50 years. Half the trail isn't even routed through the same spots.
Old Nov 3, 2012 | 10:29 AM
StrizzyChris's Avatar
U can take a stock Prius through it now!
Old Nov 3, 2012 | 11:18 AM
Freewill's Avatar
I guess the trail is always changing, but this Moses Ludel quote from his 2004 Jeep Owner's Bible always gets my attention:
"In 1967 I drove the Rubicon Trail, the tougher reverse route, (Miller Lake entrance, traveling west along Georgetown-Placerville) in a stone-stock '64 CJ-5. The vehicle had no chassis lift, the OEM side steps were in place, and the tire size was OE 7.00x15 [about 185x15] in Goodyear M&S tread style. These were bias ply tires in the 30" diameter range. The Jeep made the rugged trail without a whimper, coming out of the Ice House exit without a blemish. Driving skill is every bit as important as tires and lift kits."
A stock JK on 32" tires just hasta be a lot more capable than a leaf-sprung CJ-5 on 30s. A JKU probably needs more height to equal a JK. As Ludel says, driving skills matter.
Old Nov 3, 2012 | 04:11 PM
Stuka's Avatar
The biggest issue with a JKU is the length. It has a 116" wheel base. A 60's CJ5 had a 81" wheel base. That makes a HUGE difference. And like it said, 1967, so not really comparable.
