Sponsored by:
Sponsored by:
Help with tires
Old 07-09-2020, 09:29 AM
Duoglide's Avatar
I recently installed 35's with 373 gears. In Arizona I didn't mind as between 75-80 on the interstate I was at 2500 rpm. Now at 8200' in Colorado for the summer. Speed limit is 55-65 so for the next 3 months 5th gear is on vacation and the power sucks on climbs. I'll regear eventually but need to much other shit first.
Old 07-22-2020, 05:52 PM
Jonathan Price's Avatar
Can anyone tell me if 315/70R17 can replace my current 33x12.50r17? I know its closer to a 35 but will my current rims fit the 70R?
From my research it calculates to 12.4 (315) 12.52 (318) 0.12 (3) a 1% difference. I just don't know how much one percent difference makes
Old 07-23-2020, 06:15 AM
tjkamp's Avatar
If you are currently running a 12.5 wide 33, you can run a 12.5 wide 35. If you have enough physical space for the tire with your current suspension and fender setup.
Also, a 315/70r17 is a 35. They are virtually identical. If you look at tires that are available in both measurements, you will find that the differences in actual measurements are down to 1/10s of inches. Sometimes the metric is actually the larger tire. GoodYear MTR Ks are available in both 315/70r17 and 35x12.50 17: the 315 is 2/10 of an inch wider and 1/10 of an inch shorter. (These measurements come directly from GoodYear's website).
Jonathan Price (07-23-2020)
Old 07-23-2020, 06:44 AM
I appreciate that I have a set of 33s and 1 of them went bald due to a bad wheel bearing that wasn't replaced by the previous owner. I found the same tire with the metric measurements. I'd like to buy 3 of them and use the spare that's on the jeep and replace the spare with the best looking of the other 3 remaining good ones.
Old 07-23-2020, 08:05 AM
So if I wanted to maintain a 33-inch tire on the same rims (17x12.5) then what would the metric tire size be?
Old 07-23-2020, 09:24 AM
jedg's Avatar
I'd imagine you meant a wheel that is 17x9?
The link that will answer question is here - https://tiresize.com/converter/
Quick Reply: Help with tires
