Show your 35's!!!
Old May 11, 2014 | 06:09 PM
  #5161
dogger631's Avatar
I need to find something to fill the holes. I'm
Not a big fan of the lugs either, but I need something there when I hit the dirt.
Old May 11, 2014 | 06:15 PM
  #5162
dogger631's Avatar
Without the lugs and red inserts.
Old May 11, 2014 | 06:29 PM
  #5163
jeeparmstrong's Avatar
Default Show your 35's!!!
can they be painted black instead?
edit :just saw the next picture without and it looks great!!
Old May 11, 2014 | 06:41 PM
  #5164
dogger631's Avatar
I came up with 2 ideas, either get wide pan screws that fit the threads and plasticoat them, or machine a bead lock style ring to protect the wheels and use those screw holes to mount the rings
Old May 12, 2014 | 06:37 AM
  #5165
teamgreen666's Avatar
The protection ring painted black would probably look very good on that wheel and a little different then all the others out there ,good idea.
Old May 12, 2014 | 03:33 PM
  #5166
mhockey9090's Avatar
Vet Army
Can you guys help me out? Been trying to ask a few guys about your back spacing. I have seen all over the place here that for 35s its recommend that you use 4.5 on a 35 inch tire. But with some of the rims im seeing in here not all of them are 4.5 inch backspacing so now im confused.
Old May 12, 2014 | 03:38 PM
  #5167
Xodius's Avatar
Mine are 3.75 bs on 15x8 mb72's. Mine stick out a bit from the fender but it doesn't matter here in Nevada.
Does that help you at all?
Old May 12, 2014 | 04:00 PM
  #5168
Rubi-X's Avatar
Default 2014 Rubicon X
No lift, just XRC front and rear with Armors. Sitting on 35s and 16" Pro Comp SteeliesClick image for larger version
ID:	552502Click image for larger version
Old May 12, 2014 | 06:35 PM
  #5169
Vet Army
Not really as im military and move around a lot so unfortunately i have to abide be each state laws when it comes to vehicle crap. Only thing i can really get out of is window tint. But im more curious as to the 4.75 and 5 inch back spacing wheels i am seeing online. Most of the procomp ones all say 4.75 and im reading 4.50 is whats needed.
Old May 12, 2014 | 06:46 PM
  #5170
Cobb_Sahara's Avatar
Anything more than 4.5 and your going to rub your tire when wheelin. Mine are 3.75 and have still rubbed in the sway bar at times.
