Show your 35's!!!
Old Mar 17, 2015 | 07:28 AM
  #5561
AirJordan613's Avatar
3.5" AEV. 17" quadratec moabs. 35" Goodyear duratracs. JKS rear uppers and swaybar disconnects. Synergy trackbar, tierod, drag link. Coast 1310s. 4.88 gears and eaton e lockers. 3.8 auto. Quadratec Q9000s mounted inside the stock bumper. Too much else to list
ID:	601651   Click image for larger version
ID:	601652   Click image for larger version
ID:	601653   Click image for larger version
Old Mar 17, 2015 | 07:35 AM
  #5562
dlwaddle's Avatar
Swapped out the Atturo Trailbladrs for Nitto Trail Grapplers. 315/70/17.
Old Mar 17, 2015 | 07:36 AM
  #5563
dlwaddle's Avatar
And one more pic
Old Mar 17, 2015 | 08:13 AM
  #5564
08GreenRubi's Avatar
Originally Posted by LoneWolf
Looks great, congrats! Any regrets on moving up from the 33s? How do you like the MTs?
Sent via Jeep wave on my NSA-approved domestic espionage device.
Thanks!! No regrets at all, so far. I did shatter a U-Joint on my first trip out, but that was my fault as I went to Autozone and they gave me a "D44" u joint that exploded on me. I am now upgrading my axle shafts to Chromoly to address the added weight. I think once that is done I will be loving life.
Old Mar 17, 2015 | 06:04 PM
  #5565
rrogm2000's Avatar
Default 2015 jeep Willys
New wheel and tires
ID:	601830   Click image for larger version
Old Mar 18, 2015 | 07:01 PM
  #5566
KVJK08's Avatar
I can finally post in this! Yess. 35s put on last weekend
ID:	602013   Click image for larger version
ID:	602014   Click image for larger version
ID:	602015   Click image for larger version
ID:	602016   Click image for larger version
Old Mar 18, 2015 | 07:45 PM
  #5567
ASC-THEANVILJK's Avatar
Jeep jk angry eye project for 7 bucks!
I'm still learning this thread, quote and posting thing on here so I apologize if this is in the wrong area.
I have been a jeeper for over 6 years now and I can safely say I will not own another make for the rest of my life. Owning a 2009 JK 2 Door I really put it through some hell. Almost every modification to my rig was done by me. The chopped fenders, grill guards, suspension mods and wiring was almost all fabricated through DIY threads. I decided to get a 4 door and it has come pretty far and fast.
I have a 3 inch procomp suspension with 33 inch tires. I notice on several occasions even after adjusting my head lights that people on the highway tend to high beam me thinking I'm initially doing the same to them. I think possibly the jeep angry eye upgrade could help.
So I look online at several places and see that the jeep angry eyes range from 25 to even 50 bucks for the pair of "mostly plastic " covers. I had a bright idea to save money and just do it myself with the basic tools I had lying around. I used a can of rustoleum high temp engine enamle from Home Depot for like 7 bucks.
After removing the front grill and lights I measured 1,3/4 " from the widest point to be painted and marked it on both sides. I use tin foil quite a bit when I paint things because it's cheap (Dollar General) and you can conform and re use it several times over not having to worry about it bleeding through. Tape foil to the bulb and make sure its smooth with no errors to reduce the risk of paint runs. I did 15 light mist coats with about 10 min intervals to let dry inbetween (This is key to it coming out smooth and without paint runs) once complete I simply re assembled everything and BAM! Works and looks sweet. I don't think my lights will get to 500 degrees so overall I'm pretty satisfied all for a little over 7 bucks. It takes a full 7 days to cure but I waited overnight and put them in. Lil dust accumulated on the lense and it simply wiped right off and it's a solid coat. Enjoy!
Here are some pictures of the process.
I have more pictures from start to finish so let me know if you have a question.
ID:	602020   Click image for larger version
ID:	602021   Click image for larger version
ID:	602022   Click image for larger version
Old Mar 19, 2015 | 01:19 AM
  #5568
BFG_JK's Avatar
AEV 3.5 lift and 35x12.5x17 BFG KM2's
Old Mar 19, 2015 | 02:51 AM
  #5569
MarbleheadGuy's Avatar
Originally Posted by ASC-THEANVILJK
Jeep jk angry eye project for 7 bucks! I'm still learning this thread, quote and posting thing on here so I apologize if this is in the wrong area. I have been a jeeper for over 6 years now and I can safely say I will not own another make for the rest of my life. Owning a 2009 JK 2 Door I really put it through some hell. Almost every modification to my rig was done by me. The chopped fenders, grill guards, suspension mods and wiring was almost all fabricated through DIY threads. I decided to get a 4 door and it has come pretty far and fast. I have a 3 inch procomp suspension with 33 inch tires. I notice on several occasions even after adjusting my head lights that people on the highway tend to high beam me thinking I'm initially doing the same to them. I think possibly the jeep angry eye upgrade could help. So I look online at several places and see that the jeep angry eyes range from 25 to even 50 bucks for the pair of "mostly plastic " covers. I had a bright idea to save money and just do it myself with the basic tools I had lying around. I used a can of rustoleum high temp engine enamle from Home Depot for like 7 bucks. After removing the front grill and lights I measured 1,3/4 " from the widest point to be painted and marked it on both sides. I use tin foil quite a bit when I paint things because it's cheap (Dollar General) and you can conform and re use it several times over not having to worry about it bleeding through. Tape foil to the bulb and make sure its smooth with no errors to reduce the risk of paint runs. I did 15 light mist coats with about 10 min intervals to let dry inbetween (This is key to it coming out smooth and without paint runs) once complete I simply re assembled everything and BAM! Works and looks sweet. I don't think my lights will get to 500 degrees so overall I'm pretty satisfied all for a little over 7 bucks. It takes a full 7 days to cure but I waited overnight and put them in. Lil dust accumulated on the lense and it simply wiped right off and it's a solid coat. Enjoy! Here are some pictures of the process. I have more pictures from start to finish so let me know if you have a question.
Nice work dude but yes, most definitely posted in the wrong section haha! I think you want the 'show and tell' thread... 😊
Old Mar 19, 2015 | 04:04 PM
  #5570
Watercop's Avatar
Got new BFG KO2's ! 315/75/16. Pretty sweet. Replaced duratracs 285/75/16. So far so good
ID:	602100   Click image for larger version
ID:	602101   Click image for larger version
