Alternate CB Antenna mounting
Sweet, thanks for the tips! And yes, I was about to splice back together that which I had cut. The only other question I have is where did you hook up the power? Did you run it thru the firewall or what? I have installed my Cobra on 4 different TJ's, don't lnow where to run it in the JK tho.
Thanks again
Thanks again
Thanks for the great writeup, John.
I'm not even going to mention the lame places thought of putting the CB box. Your under-glove-box solution is perfect. I followed it today, along w/CAPSAM54's firewall solution (https://www.jk-forum.com/forums/showthread.php?t=10014).
Did you just stuff the wires into the battery terminals, or wire them into a fuse? I'd like to do the fuse way, but not sure how.
I had already bought CoolTech's license plate mount. Now I'm reading about folks ripping off their plates on the trail. I guess I'll wait for it to happen, then move the mount to the center.
Thanks again,
Thanks again,
Thanks again,
Thanks again,
OK, I ran my positive wire directly to the battery terminal (via crimp terminal) and ran the negative to a conveniant ground screw adjacent to the fuse box. The positive lead already has an inline fuse so I didn't bother with another one.
My only (small) regret is that when I lift the jeep the antenna won't clear the garage door. Then I guess it'll be time for a new house!!
disconnects work fine, I have a mount that tilts to the side on my TJ. I'm going to get the same thing for my JK. But I've read 18 is not long enough to run in a 4 dr? I have the same Cobra 75 and plan on just buying the under dash module for my JK.
And another bonus of the 3 ft firestick is it lays perfectly under the trunk lid right above the tire jack opening so it would difficult for someone to steal it! I put my microphone in a zippered canvas pouch in the trunk so I have everything with me and fairly secure.
Not sure what you're asking here, do you want to know what i used to make the hole in the panel? If so, I used a .750 hole saw if I remember right.
