Bedlined Front Grill!
Old Apr 19, 2010 | 03:30 PM
  #121
nikbass's Avatar
Originally Posted by hiddenprey
well I did it finally, only took a year. Have not done the JEEP letters Yet but will be done in yellow this weekend at the same time i do the Trail Rated Badge
What are you using for the Yellow? I'm having trouble finding a good match yours seems to be close.
Old Apr 19, 2010 | 07:48 PM
  #122
hiddenprey's Avatar
for my grill inserts i used a yellow primer then bright yellow rust check paint. but tell you the truth it is now 3 weeks old and it is fading fast. might try a brighter yellow.
as for the letters and badge i bought the D yellow spray paint from the dealer, 20 bucks a can here so i use it wisely. letters are done but badge is not, will have pics soon
Old Apr 20, 2010 | 11:28 AM
  #123
nikbass's Avatar
Thanks, I didn't realize you could get spray at the dealer. I got some Touch Up with a brush - Pin deal and it doesn't match at all. Well it's kind of yellow but very not right.
Old Apr 23, 2010 | 04:20 PM
  #124
Flyingbrian's Avatar
its now added to the list ..great pics by the way..
Old Apr 30, 2010 | 06:10 PM
  #125
skmcvay's Avatar
Wow a great write and great mod. How does it hold up to lovebugs? this would look great with the stock wheels done too
Old May 3, 2010 | 07:26 PM
  #126
BIGJ's Avatar
finally did mine, great mod and too easy
Old May 4, 2010 | 06:44 AM
  #127
ProjectJK08's Avatar
what im curious about hiddenprey is, how did you get the rings around your lights to stay yellow? its a small detail but i really like it
Old May 4, 2010 | 03:45 PM
  #128
hiddenprey's Avatar
when i had the grill off i decided to paint the ring around the head light yellow and i like it alot as well.
I will be redoing the yellow as the paint i used is fading fast.
Old Jun 11, 2010 | 09:57 PM
  #129
Northern Wrangler's Avatar
Originally Posted by Northern Wrangler
Did mine today. Very pleased with outcome. Pics to follow.
Guess I never got around to posting pics. Well today I decided that the grill had faded too much and needed to be redone. I originally used the "EZ" liner like the OP. After I prepped the surface I used the "EZ" adhesion promoter to aid with the bonding of the bed liner spray. It looked good initially but the liner faded in the sun. The other thing I did was after removing the JEEP letters I left a layer of the foam tape used to attach the letters behind. After I bed lined the grill and the remaining foam tape I was able to see exactly where the letters would reattach. This worked out really well and I had no issues putting the letters back on with double sided 3M tape. Anyways, I never added pics from the original process but I'll attach pics from today.
After noting the grill had faded, I removed it, cleaned it and used this really good flat black paint that I found at Home Depot. This stuff comes out of the can really black. I've noticed with other black paints that as it comes out of the can onto a surface its almost see through (if that makes sense? ). I used three coats of this paint on the grill and light guards which I left attached as they were also starting to fade and rust a little.
Pics attached.
ID:	72202   Click image for larger version
ID:	72203   Click image for larger version
ID:	72204   Click image for larger version
ID:	72205   Click image for larger version
Old Jun 11, 2010 | 10:01 PM
  #130
More pics. These are of the finished product after being painted and installed.
ID:	72210   Click image for larger version
ID:	72211   Click image for larger version
