Building Storage Box, What would you want yours to have?? Give Input!
I filled my box last night:
In the jk storage
small compartment:
Jack
socket
braker bar
larger compartment:
Ratchet/crecent
obdii reader
mx saw
high temp silicon seal
hand held color gps
in the box:
Hi lift jack base
hi lift wheel straps
hi lift bumper hook
spot light
cb
trail books/maps
trailer hitch
d-ring tow hitch
port compressor
rope
tow straps
i also have survival gear in mil spec ammo cans that will fit on the sides of my box should the need arise.
In the jk storage
small compartment:
Jack
socket
braker bar
larger compartment:
Ratchet/crecent
obdii reader
mx saw
hand held color gps
in the box:
Hi lift jack base
hi lift bumper hook
spot light
cb
trail books/maps
trailer hitch
d-ring tow hitch
port compressor
rope
tow straps
Can you post a pic of it in the jeep?
Also, how wide did you make it? I'm making one soon here, and here are some thoughts I had, I'd love your view/opinion:
The floor seems mostly flat, but there are "bumps" just inside the wheel wells. I'm not sure whether to build the box wide enough so that it sits ON the bumps, or INSIDE the bumps. What'd you do?
My plans (for now, at least :S ) are to build a box that WOULD sit on the bumps... but remove the floor carpet piece, and strategically place 4ish rubber "blocks" so the box will "float" slightly above any metal pieces on the floor. I'm planning on removing the 2 front-most cargo hooks, and screwing the floor of the box to the floor using those bolt holes.
Design sketches to follow...
I LEFT THE SPACE SO I COULD STILL PUT GROCERIES AND 2X4'S ETC. W/OUT HAVING TO UNLOCK AND LOCK THE BOX.
