Cibie Euro-code headlamp install
Old 01-14-2007, 11:35 AM
Cruiser's Avatar
Did the lights fit with the stock trim ring or did you need one from an 06? And if you could post the beam pattern.
I'm putting off bigger tires so I have the cash for better lights.
SC
Old 01-14-2007, 02:41 PM
jpaddict's Avatar
Cruiser, the stock ring fits. The '06 ring DOES NOT.
The beam pattern is exactly like the above link, if you scroll down.
Old 01-14-2007, 03:34 PM
jkmon's Avatar
So is this the choice for headlamp upgrade for our JK's? So if were using a relay in this setup, I'm assuming you guys spliced into the factory wire, (turn-on) So what happens to the factory headlamp harness? There should be voltage in that wire correct? Is there a fuse to remove.
Old 01-14-2007, 05:44 PM
HUMONGO's Avatar
If anyone is planning on doing this, could you do a write-up specifically on the harness. DS' site is great, but again, quite confusing. I either need detailed pics and directions or somebody to hold my hand while I grudge my way through it.
Old 01-14-2007, 07:49 PM
Rubimon's Avatar
jpaddict, Have the dealer get you an under hood light. The harness is there, just no light. Be pushy, I have the same situation and they are getting me one. A drivers side footwell light too!
They are telling some people they don't come with it anymore. I think most of theose people don't have the harness either.
Great light mod! I may have to do that.
Rubimon
Old 01-20-2007, 12:40 PM
jpaddict's Avatar
I have additional photos of the lights turned on, with the "city light"feature, and then two photos demonstrating the sharp optical cutoff of the Cibie light.
PM me if you can post them for me (small file size).
Old 01-21-2007, 12:45 PM
Military Jeeper's Avatar
Sent PM.........let me know.
Old 01-21-2007, 03:40 PM
jkmon's Avatar
Did you cut the old headlamp harness? or is there some sort of pig tail harness with the new lights?
Old 01-21-2007, 04:28 PM
HUMONGO's Avatar
I think there's a whole new harness, no involvement of the old one.
Old 01-21-2007, 05:16 PM
jpaddict's Avatar
The old harness remains in place. Since you are building two relay circuits, you take the low beam feed off one side, and the high beam feed off of the other. There are three wires at each respective plug--High, how, and ground. I cut the low wire, and connected it to #86 on the relay circuit (low beam) feed, and the high from the other side, connected to #86 of your high beam circuit.
The stock wiring is only 20 gauge, and useless for anything other than tripping the relay.
Your light controls will function exactly as they do now, and the fogs will cut off on high beam circuit.
Quick Reply: Cibie Euro-code headlamp install
