D-Ring Silencers (Stop The Clank)
Old Jan 8, 2009 | 02:48 PM
  #81
rangleme's Avatar
I got these as well and havent installed them as of yet. Maybe tonight I will, it's a cheap and easy idea!
Old Jan 27, 2009 | 08:58 AM
  #82
dlud51's Avatar
Default Priceless!!!!!!
Just went to the local hardware store (just happens to be called Gay's...go figure) I asked the guy at the plumbing counter for the Ballcock Shank washers and his face was absolutely priceless....He was like I have NO idea what you're talking about...turns out they did have them but they're just called shank washers.....
To make things worse I then asked if they carried quick fist clamps (so I could do the rear door shovel mount mod)....he must have thought I was crazy.
Old Jan 31, 2009 | 12:49 PM
  #83
dlud51's Avatar
I did this simple mod today and man does it work.... I shaved the ballcock washers ($0.79 ea. at the local hardware store) a bit and then squeezed them in place....the shackles don't even move let alone clank off the bumper.
Great mod!
Old Jan 31, 2009 | 06:53 PM
  #84
PoconoJack's Avatar
Great mod!
I guess Gay's True Value didn't hook you up? Where did you find them? I went to Lowes and got the same face you must have!
Old Feb 3, 2009 | 07:42 PM
  #85
Roxster's Avatar
Great tip, but now that I've got d-ring mounts and shackles I found they don't clank or rattle at all.
Old Feb 4, 2009 | 04:32 AM
  #86
Macavity's Avatar
It's a ballcock shank washer. It better be cheap and easy!!!
Old Sep 2, 2009 | 08:32 PM
  #87
hvilla's Avatar
Great idea man!!! I was looking for something like it!!!
Old Oct 30, 2009 | 06:34 AM
  #88
cajunaviator's Avatar
I have a Flame Red JK, so I used the red plasti dip, but I had to thin it out with naptha in order for it to evenly coat the shakles. I put two coats on them and they are holding up great, along with matching my JK. I just may use the ballcock shank washer on them as well.
Old Oct 30, 2009 | 01:13 PM
  #89
sixt7gt350's Avatar
I did something similar, using 3/4" ID hole grommets on either side of the bumper boss.
The ballcock shank washer is pretty ingenious, though.
Old Oct 30, 2009 | 02:39 PM
  #90
midwesterner's Avatar
I added these a couple weeks ago and they are a perfect fit. If I didn't know any better I would have thought they were made for this purpose.
Maybe shackle shank washers would be a good name:-)
