Disable/Enable feature codes/sequences
Old May 19, 2012 | 03:53 PM
  #91
AdvJeep's Avatar
Yes the only downside would be your battery would drain just alittle faster but if you have the stock stereo and nothing else on then you can run it for awhile. Just make sure you start it up every once and awhile to charge the battery.
Old May 22, 2012 | 11:16 AM
  #92
maddmatt9400's Avatar
Awesome thread.
Subscribed!
Old May 22, 2012 | 07:22 PM
  #93
JRockman's Avatar
Great thread! Subscribed
Old May 25, 2012 | 11:54 AM
  #94
ColeRedRubi's Avatar
When I do the ESP off code it turns off the ESP but dings twice every time I stop. Ideas? ESP off is waaay better on the dirt!
Old May 25, 2012 | 06:38 PM
  #95
jkrubcon's Avatar
Explain the method your using
Old May 25, 2012 | 07:31 PM
  #96
Bosco109's Avatar
Originally Posted by Wolfesneck
I used to have a delay on my headlights but now I do not. Any sequence on resoring this feature?
I noticed if you turn the engine off before your headlights, they stay on. Turn them off before the motor and they should go off.
Old May 25, 2012 | 09:16 PM
  #97
Redman333's Avatar
Originally Posted by AdvJeep
You have two options first turn the key to the "on" position the the dinging stops in a few secs, the second option is unplug the wiring harness for the doors you want to keep open. When you unplug the doors the sensors are disabled and no dings come from the jeep. Enjoy the tunes!!
I could be wrong but on my 2012 i had unplugged just the drivers side and didn't take the doors off and that stopped it. It seems it only monitors the drivers door.
Old May 26, 2012 | 06:10 AM
  #98
jbl's Avatar
jbl
I have a 2012 jk. The ESP off code won't work. Are the codes different for newer models? Where do I need to look to find these codes? I hate ESP! Please help me.
Old May 26, 2012 | 09:59 AM
  #99
FlameRedJK's Avatar
Originally Posted by fpnyc
Putting your seatbelt on Also turns off the seatbelt chime
Common sense WIN hahaha
Old May 26, 2012 | 10:02 AM
  #100
FlameRedJK's Avatar
Actually learned this from a friend with a CJ7?? But in the 2012 if you just hold down the ESP button for 30 seconds or so it will disable the ESP...has to be redone every time you turn the engine off and back on but very handy
