Disable/Enable feature codes/sequences
Old May 13, 2012 | 07:40 PM
  #81
fpnyc's Avatar
Putting your seatbelt on Also turns off the seatbelt chime
Old May 13, 2012 | 08:04 PM
  #82
Fivepack1966's Avatar
subscribed!
Old May 13, 2012 | 08:06 PM
  #83
jes1848's Avatar
So the OP mentioned secret stashes... i know this is out of place but what exactly are some of them?
Old May 14, 2012 | 06:28 AM
  #84
Wolfesneck's Avatar
Default Delayed headlights
I used to have a delay on my headlights but now I do not. Any sequence on resoring this feature?
Old May 15, 2012 | 08:27 PM
  #85
Chamoru's Avatar
Is there a way to enable lockers on 2012 Rubicon while in 4HI?
Old May 19, 2012 | 12:36 PM
  #86
jkrubcon's Avatar
OK, so I want to listen to the radio with the engine off and the doors open, how do I stop the diiinnngggiiinnngggg?
Old May 19, 2012 | 01:49 PM
  #87
AdvJeep's Avatar
You have two options first turn the key to the "on" position the the dinging stops in a few secs, the second option is unplug the wiring harness for the doors you want to keep open. When you unplug the doors the sensors are disabled and no dings come from the jeep. Enjoy the tunes!!
Old May 19, 2012 | 01:51 PM
  #88
jkrubcon's Avatar
First option doesn't seem to work ????
Old May 19, 2012 | 01:56 PM
  #89
AdvJeep's Avatar
Two clicks forward? All the lights on the dash will light up and run through it's diagnostics. Every vehicle I have worked on or driven works this way, if you do one click "acc" then it will ding. Hope it works for you if not, complain to your dealership!
Old May 19, 2012 | 02:06 PM
  #90
jkrubcon's Avatar
Ok, I understand that now. The only thing I don't like about that is everything else wants to be on. Is that OK to do?
