Disable/Enable feature codes/sequences
Old May 26, 2012 | 08:10 PM
  #101
Tx98Formula's Avatar
I can not get the ESP to turn off on my 2011!! Do you guys do it with it running or just the key in the on position? Also i might of missed it but is there a way to turn off the tire pressure light?
Old May 27, 2012 | 05:30 AM
  #102
jkrubcon's Avatar
Originally Posted by FlameRedJK
Actually learned this from a friend with a CJ7?? But in the 2012 if you just hold down the ESP button for 30 seconds or so it will disable the ESP...has to be redone every time you turn the engine off and back on but very handy
How is this any different than just tapping the button once and turning it off?
Old May 27, 2012 | 03:05 PM
  #103
FlameRedJK's Avatar
From my understanding, it completely disables it.
I would be curious to know more about it myself though, as far as the difference
Old May 27, 2012 | 03:43 PM
  #104
augustk5's Avatar
Subscribe !!!!!
Old May 27, 2012 | 03:49 PM
  #105
AdvJeep's Avatar
There is an explanation on the cd manual, basically just pushing the button once delays the traction control but still has it activated, if in 4 hi you can completely disable this by pressing and holding for 7 sec. But it resets if you go into 2 hi or turn off the jeep. Doing the steering wheel dance turns it off in all ranges and stays off till you do the dance again. If you drive on snow you can really notice the differences
Old May 27, 2012 | 04:14 PM
  #106
Bodar's Avatar
Works on my 11 mojave edition quite nicely. And mine was running.
Old May 27, 2012 | 07:48 PM
  #107
BlueBennett's Avatar
Default TPMS Disable??
How do you disable the Tire pressure monitoring system. I put 35's and XD wheels on my 2010 Rubi and my light comes on and chimes everytime i start the engine.
Old May 27, 2012 | 07:50 PM
  #108
TURTLECON's Avatar
Superchips
Old May 27, 2012 | 11:35 PM
  #109
I tried that with my Superchips but it only let me adjust the pressure alarm. I turned it down to the lowest pressure witch is 26psi, but the light and chime stil comes on everytime i start the engine.
Old May 28, 2012 | 08:01 AM
  #110
TURTLECON's Avatar
There's a free download on Superchips website for TPMS OFF ROAD which will turn it off. You'll have to connect your unit to your computer and update/download the new software.
Make sure all your tires are over 26psi, including the spare. If the chime & indicator still comes on, then there's something else wrong.
