DIY On-Board Air
Old Sep 22, 2008 | 05:40 PM
  #31
Cesar's Avatar
I like this one..looks good.
Old Sep 24, 2008 | 09:09 AM
  #32
Dwikto's Avatar
so question, can you run two air compressors at the same time, ie one for the front tires and one for the back tires. I wired a power port to the back of my bax and was wondering if the alt or battery would die by doing this???
Old Sep 24, 2008 | 06:52 PM
  #33
you should be able to viair's X-treme system comes with 2 compressors and a 2 gal tank. however now that i think about it, that might be so when one is at a cooldown point the other can be running. i think the rule is somethin like 15 min. on 15 min off.
if you can run two im sure we will find out from someone soon
Old Sep 24, 2008 | 10:34 PM
  #34
Lust4Life's Avatar
ALG : this is a couple months old
long live a good idea though
you could run two but it would put a considerably higher amount of draw on the electrical system
you put in a fast idle switch to up rpms on demand to help out
a second battery or a capacitor would be good
but at that point you should be thinking about a different system entirely
THIS is an excellent setup though
it would be nice to work out a fitting setup that did not require a hose clamp though
Excellent work
Old Sep 25, 2008 | 07:26 PM
  #35
Roxster's Avatar
Originally Posted by Lust4Life
ALG : THIS is an excellent setup though
Excellent work
Thanks! I wasn't concerned about using a hose clamp with this set-up as I'm only using it to a max of about 35 psi. If I install a tank I'll replace the cut section of hose with a prefab 2' section with factory installed NPT connectors on the ends.
Old Sep 26, 2008 | 07:49 AM
  #36
MikeReo's Avatar
I have not been able to find a compressor like this in any of the stores around me. I have found one at Cosco similar in size but it use a 120v plug. Could I hard wire this to my battery with some thick guage wire? I need somethiong better than a 12v hookup but dont have the cash right now for an expensive setup...any feed back would be appreciated. Thanks, Mike
Old Sep 26, 2008 | 08:05 AM
  #37
MikeReo's Avatar
better yet...would it be possible to splice a set of jumper cables into the 120 v wireing?
Old Sep 26, 2008 | 08:11 AM
  #38
vgullotta's Avatar
No, don't do that.
http://www.google.com/search?hl=en&q...F-1050+Tsunami
You can get them at Pep Boys if you have one of those near you.
Master Flow MF-1050 Tsunami Air Compressor.
Old Sep 26, 2008 | 10:46 AM
  #39
skaggs9573's Avatar
Going to check my local Harbor Frieght Store to see what types of compressors they have, any suggestions?
Old Sep 26, 2008 | 11:11 AM
  #40
skaggs9573's Avatar
I found the same compressor at my local Sams Club for $51.12, I'm going to go pick one up today after I get my AEV Bridgers put on. This will be a good project for the weekend.
