Drilled the side view mirrors!
Old Jan 29, 2015 | 10:05 AM
  #761
JonathonK's Avatar
Default Front Page Coverage
Great stuff! Thought we'd make the front page crowd aware too...
Quick 'n Easy Mirror Fix for You Wrangler Owners - JK Forum
Old Apr 19, 2016 | 09:46 PM
  #762
ShinyPartsUp's Avatar
Default Is this still a needed mod on newer JK's?
Anybody know for sure whether there was a design change or not to the mirrors on '15 or '16 model years? Is there still a need to perform this mod?
Old Apr 20, 2016 | 07:36 AM
  #763
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
Great question. I've had my 15 for over a year and I don't think I've ever washed it.
I'll pour some water in there and see what happens.
Old Jul 11, 2016 | 07:28 PM
  #764
smith7200's Avatar
I've got a 2016, and there is a small notch and V shaped cut out in the gasket at the bottom of the mirror.
Old Jul 11, 2016 | 09:48 PM
  #765
mds22's Avatar
there is a notch but it gets clogged up easily and still doesn't drain right.
Old Jul 20, 2016 | 06:30 AM
  #766
Woods's Avatar
JeepSWAG
My 07 has a notch too. I havn't pulled my 15's mirrors to check any differences yet.
Old Nov 5, 2016 | 12:59 PM
  #767
mredjeep's Avatar
Default Thanks !
Great Fix ! If only the Factory did that my Hinges wouldn't have gotten messed up!
Old May 23, 2017 | 05:07 PM
  #768
JeeperIPA's Avatar
Default Even on a 2017 JK
Came across this thread and noticed it was several years old. Decided to look at my side mirrors and sure enough, even on my 2017 JK, the weep holes as designed don't work well and were also plugged with dirt after only 400 miles. Drilled 3/32" holes in the bottom of each mirror, water drains out readily.
Old Jul 6, 2017 | 11:48 AM
  #769
3rd-go-around's Avatar
Originally Posted by jeeperipa
came across this thread and noticed it was several years old. Decided to look at my side mirrors and sure enough, even on my 2017 jk, the weep holes as designed don't work well and were also plugged with dirt after only 400 miles. Drilled 3/32" holes in the bottom of each mirror, water drains out readily.
where did you drill the hole? Got a pic of it
Old Jul 14, 2017 | 06:41 AM
  #770
cptnmurff's Avatar
Vet: Army
Default My freinds Jeep had this issue...
My friends Jeep had this issue. I shared this thread with him. He drilled his side mirrors. No more problems. We both say THANKS...
