Dynomax 39516 used on 2 door.
Old 10-15-2014, 04:27 PM
Flexer07's Avatar
Default Dynomax 39516 used on 2 door.
The Dynomax cat back turn down (39516) is only offered for a 4 door but will work on a 2 door with a few modifications. I chose this exhaust system for a few reasons I had to have a turn down due to my rear coilover setup, the price was great, and I don't trust local shop for custom work. For the modifications I had to do is trim the turn down after the muffler 1.5" then I used this adjustable hanger http://www.lmperformance.com/67163?g...FcRAMgodHB0A3A to use the factory hanger mount. The exhaust has very little cab drone if any. And is quite at normal speeds but has a nice deep ton if you get in the pedal. I'm typically not a turn down person but I'm really satisfied with the setup. And the dynomax rep on here is outstanding on service.
Old 10-28-2014, 12:05 AM
Gowheelin's Avatar
I like this option. thanks for the heads up.
Old 10-28-2014, 01:10 AM
kjeeper10's Avatar
I need to do something similar.
Ty
2007 Rubicon /2 door/6 speed
Old 10-31-2014, 07:43 PM
Sharkbait98's Avatar
I did the same setup, I think with the same muffler even. Its been on there for about a year but had a local shop install it all for 60 bucks
Quick Reply: Dynomax 39516 used on 2 door.
