Fuel Door Installation
Old Dec 26, 2009 | 03:50 PM
  #131
JeepNDad's Avatar
Originally Posted by 08RubiUnlimited
It's super easy to do JeepNDad...BTW glad to see a fellow Shen Valleyite here. I'm down in Fro Ro myself.
Glad to hear you are pretty close by. I know who to call on for help now if I need anything.
Old Dec 27, 2009 | 08:43 AM
  #132
JeepNDad's Avatar
Thanks for the write ups guys. Went pretty smooth.
Old Jan 1, 2010 | 06:44 AM
  #133
mefly2's Avatar
Can the door be used with a locking gas cap; or is it specfific to the one supplied?
Old Jan 1, 2010 | 07:38 AM
  #134
Steve's 95YJ's Avatar
Hi mefly2, yes you can use the fuel door with a locking gas cap........that's exactly the set up that I have.
Old Jan 25, 2010 | 09:14 AM
  #135
SAXON's Avatar
My first mod. MOPAR fuel Door.
All I can say is,, what a pain. You would think something from MOPAR made for one of there vehicles would fit better. The install is straight forward but it ends there. Getting the old housing off was not to bad, but putting the new housing in for the fuel door was a bear. The two lower clips went on ok. There was no way the upper push clips were going to seat right. I had around a 1/16th of an inch of the upper clips what would not push behind the sheet metal. And this is with the housing’s collar pushed flat to the sheet metal.
To make a long story short I used my grinding tool and I took off around a 1/16th of an inch from the upper push tabs on the housing. Well look at this it fits ,,Hurray, And only after 1.5hrs off getting pissed. I still have a very small gap between the housing and the sheet metal, the thickness of a piece of paper but it’s tight. I’ll wait for some warmer weather and put a small bead of RTV around the top of the housing ware the gap is. No dig deal.
Old Mar 15, 2010 | 03:42 AM
  #136
AV8R72's Avatar
I just bought a 2010 Unlimited Sahara, and was trying to install the mopar black fuel door the other day. I can't seem to get the old mounting off. I was able to get the two visible clips pressed and past the metal, but could not "work" the hidden clip(s) out. Any ideas as to how I might try this again? Also, how does one get the rubber seal off? I couldn't get that to budge a all. Any help would be appreciated. If I can't get it done on my own, I'll probably take it to the dealer and have them do it. I just don't want to dish out more cash when it's something I can do on my own. Thanks in advance.
Old Mar 15, 2010 | 05:21 AM
  #137
Hop45's Avatar
I recently installed mine and had the same issue. I am not very mechanically inclined, but what I did was wiggle/rotate the old housing after releasing the 2 visible clips. It eventually worked it's way out. I did notice a very small "crack" in the sheet metal at about 7 o'clock on the cut out. Did not appear to be a big deal. New one popped right in. I love the new look!
Old Mar 15, 2010 | 08:20 AM
  #138
jpthunder's Avatar
does anybody know who makes it for jeep? It looks really similar to an aftermarket one.
Old Mar 15, 2010 | 09:40 AM
  #139
AV8R72's Avatar
Mopar makes the "officially" licensed products for Jeep. Go to mopar.com.
Old Mar 15, 2010 | 09:44 AM
  #140
Hop45's Avatar
The one that says "Jeep" is made by MOPAR.
