Grill Mod
Old Nov 9, 2010 | 03:05 PM
  #841
sciguy6's Avatar
Gutter guard on sale, friend from local phone service hooked me up with ties and tie blocks. Had Gorilla glue from fixing a table. 2 1/2 hours (not including Gorilla glue wait time) Cost: $2.39 + tax.
The thing that took the longest: Getting the sticky stuff off the back of the tie blocks.
Looks great. I know, I know. Pics. But I haven't figured it out yet. Looks just like one of the posts early on in this thread.
Old Nov 10, 2010 | 05:42 AM
  #842
JonesN's Avatar
Is it necessary to take the sticky stuff off the backs of the tie blocks? I have all the materials to get started on mine; but I hadn't planned on taking the sticky stuff off when I epoxy/gorilla glue them down.
Old Nov 10, 2010 | 06:11 AM
  #843
johnr41a's Avatar
I took them off b/c I read here that eventually those pads fall off. I soaked mine in alcohol overnight and just peeled them off the next day. Then gorilla glued plastic to plastic.
Old Nov 10, 2010 | 09:19 AM
  #844
DDloadedJK's Avatar
I recommend plastic to plastic but put a drop on the stick part then I put the glue around the edges of the blocks. Hope it holds.
Old Nov 10, 2010 | 01:48 PM
  #845
hx15537's Avatar
If you epoxy up around the tie down, you may not need to take the foam off of the back.
Personally, I would spend the 10 min taking them off. It's a whole lot easier to remove it from the start and know that you have a good bond than to have some of them pop off a week down the road and start over.
Old Nov 13, 2010 | 11:15 AM
  #846
JKOMP's Avatar
Just got done with my grill mod. Thanks for great instructions. Took me a couple of hours and one of the easiest mods I've done. Got the aluminum sheet from Lowes, JB weld, zip tie blocks, and zip ties.
ID:	101844   Click image for larger version
Old Nov 13, 2010 | 11:55 AM
  #847
JonesN's Avatar
Do you happen to have the item number of the sheet metal you got from Lowe's?? Should be on the receipt...
Old Nov 13, 2010 | 07:51 PM
  #848
JKOMP's Avatar
Yeap Item #: 103626 | Model #: 11244
Old Nov 19, 2010 | 12:04 PM
  #849
ScottG's Avatar
So easy even a 2 year old can do it
Old Nov 21, 2010 | 05:46 PM
  #850
sky's Avatar
sky
[QUOTE= silver or black[/QUOTE]
Silver fo sho!
