Heated washer fluid
Old Mar 15, 2012 | 08:47 PM
  #31
rinkishJK's Avatar
Still working like a charm!
Old Apr 1, 2012 | 01:29 PM
  #32
SNOWHARA's Avatar
Cool. I am going to give this go next weekend. We'll see how it does with bugs guts first and then ice next fall. Or ice next week. The weather has been kind of unpredictable up here lately. Great idea!
Old Apr 1, 2012 | 06:05 PM
  #33
lolpetewtf's Avatar
Originally Posted by marsolek84
I just tackled this mod this weekend, but went a little different route. I picked up the same 6' rubber hose and white pieces, but instead of using the main radiator hose to warm the fluid I used the hose that runs from the engine block to the heater core. This hose in on the pass side of the engine. There will be two hoses there, one to supply the heater core as well as a return line. There is a big difference in the ammount of heat so make sure you get the supply side.
Great job! Thanks for saving me a ton of $$$
Which side is the supply side?
Old Apr 1, 2012 | 07:10 PM
  #34
rinkishJK's Avatar
My guess would be the top hose. Use a thermometer and measure both to find the warmer one.
Old Oct 5, 2012 | 10:00 AM
  #35
Vladimer's Avatar
Tis the season! How many wraps did you guys do around each hose? I would rather not end up with scolding hot fluid
Old Oct 5, 2012 | 11:25 AM
  #36
rinkishJK's Avatar
I just wrapped it around the upper rad hose, not the heater core hose.. BTW since I've done this not one issue at all.
Old Oct 5, 2012 | 02:48 PM
  #37
Vladimer's Avatar
Ah ok, well that is good to hear. Would you say you did 5-10 wraps to make sure enough heat got in? or just a couple
Old Oct 5, 2012 | 06:31 PM
  #38
Otten's Avatar
Pic attached
Old Oct 5, 2012 | 06:38 PM
  #39
rinkishJK's Avatar
Originally Posted by Otten
Pic attached
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=374650"/>
I like the green tube. Nice job. Very clean.
Old Oct 18, 2012 | 05:17 PM
  #40
NAlbertaJK's Avatar
Awesome mod. Can't wait to see how it performs in the -40C that we get here I the winter in Northern Canada
