Homemade Tiedown Rails
Old 01-16-2011, 01:32 PM
Notakar's Avatar
Default Homemade Tiedown Rails
Developed these "tiedown rails" for the storage area of my 2008 X Unlimited - took about 30 minutes do make the rails, plus the time for the paint to dry
Attachment 118278
Picked up a couple of 36" long 1-1/2" slotted angle pieces from Home Depot trimmed them to 33-1/4" in length, then did some light grinding to smooth the edges and corners
Attachment 118277
Grabbed my T40 torx and removed the roof bolts from one side of the rear cargo area...
Attachment 118275
... and centered the rails holes on the middle roof bolt hole
Attachment 118276
Marked where the outer roof bolts need to go and and removed the materials as needed to let the outer roof bolts pass through the rails. My cut was kinda rough (the second one was better) but it's hidden under the bolt anyway.
Attachment 118280
More to follow...
Old 01-16-2011, 01:35 PM
Notakar's Avatar
The rail should line up nicely between the pin just behind the back door and the rear of the JK
Attachment 118286
Double check fit by installing the roof bolts and making sure nothing is out of place
Attachment 118287
Paint to your preference and install - i used Rustoleum "truck bed liner" the textured black looks good in my Black X Unlimted
Attachment 118288
COST - about $25 including the paint
CAUTIONARY NOTE - the slotting is different on each face of the angle so, if your as anal as I am double check your setup. I'm going to have to redo one side. Not sure which yet.
Old 01-16-2011, 02:06 PM
ronjenx's Avatar
Very nice. It's simple, and functional.
Old 01-16-2011, 03:13 PM
08{GA}RUBICON's Avatar
I like it! Thanks for the write up!
Old 01-16-2011, 03:42 PM
bigd6943's Avatar
Thumbs up
Looks good man I will do it next week.
Old 01-16-2011, 04:17 PM
Notakar's Avatar
Thanks guys
I try to tell my wife that wandering around home depot is not a total waste of time
Old 01-20-2011, 03:02 AM
yamil008's Avatar
I did it last night! Woohooo!
ID:	119629   Click image for larger version
ID:	119630   Click image for larger version
ID:	119631   Click image for larger version
Old 01-20-2011, 03:17 AM
JK Bostonian's Avatar
Great idea, gonna do it this weekend. Thanks.
Quick Reply: Homemade Tiedown Rails
