Mopar Heated Seat Install
Old Sep 7, 2008 | 06:50 PM
Gokracer1's Avatar
Nice Write Up!
Old Sep 7, 2008 | 07:33 PM
sickchilly's Avatar
Originally Posted by ksroqclimber
I did this back in January. Thought I would post my location for the controlers.
I have CoolTech's Switch panel so i couldn't really put it where the directions said to and make it look good.
So i decided to put it by the cup holders.
Ks
Nice... that was my 2nd choice for switch location. I ended up putting mine below the power window switches since I have a 2 door. Fits perfectly there. I have the Daystar switch panel, so couldn't mount it where MOPAR wants you to.
Old Sep 7, 2008 | 07:35 PM
sickchilly's Avatar
Originally Posted by KootenayJK
I would like to add (being about 1/3 of the way through this myself) that should you choose to purchase hog ring pliers for the job, buy ones something like these:
Hog Ring Pliers are one of those tools you will probably only use once, but when you need them, you really need them. Completely sucks trying to do the job without them.
But my MOPAR kit came with a decent set of pliers. Didn't yours? They're definitely cheap, only good for a few uses, but they got the job done.
Old Sep 8, 2008 | 12:47 PM
windnsea78's Avatar
Great install! I just have questions about the power source...I see the switch but where did you hook up power? Is there already a dedicated source for heated seats?
Old Sep 8, 2008 | 01:17 PM
Brad2893's Avatar
Anyone try to get the heated seat switches that come out of other DCJ vehicles? They're the same as the disco/locker switches. Would look really good down by the shifter, like stock.
Cheers.
Old Sep 8, 2008 | 09:06 PM
sickchilly's Avatar
Cheers.
Good luck with that... those switches are CAN-bus. You'd have to also get the computer control module for the heated seats out of another DCX vehicle, figure out how to tie it into the CAN-bus, then hope and pray that you can find a feature code for the dealer to enable on your JK so they work. Fat chance at that, I'm sure unless heated seats are offered in the JK outside NA?
Old Sep 10, 2008 | 09:37 PM
sly's Avatar
sly
Default 07
hey one question will this work on 07s and will it be the same thing just plug and play?
Old Sep 10, 2008 | 09:40 PM
sickchilly's Avatar
The Mopar harness piggybacks onto the cigar lighter. Plugs right in, no splicing or anything.
Old Sep 10, 2008 | 09:41 PM
sickchilly's Avatar
Works on any JK.
Old Sep 20, 2008 | 05:47 PM
homer's Avatar
also somone posted the instructions a few months back as well:
http://www.project-jk.com/images/pdf...eatedSeats.pdf
Ks
Was there any issue of the factory harness not fitting into the power supply because you mounted in the console?I have the kit and plan to install in 2 weeks. I like your setup bettre the the jeep design, but do not feel like having to splice wires.
Thanks
homer
