The Results are In....
Old Dec 6, 2006 | 01:13 PM
  #51
Jeephrog's Avatar
Originally Posted by 1BADJK
Hello All; As for sound, its noticeable.. Unbearable, not really.. Its only really noticeable under load.. Taking off, etc.. With just a soft-top you can barely here it going down the highway @ 70.. At least now it sounds like a jeep.. I will try to get some sound clips up this weekend..
Low RPM torque - @ 1650 it was averaging gains of 26.5hp / 25tq.. Not bad to me..
I don’t have any hook ups as for the parts. I paid full retail..
- $250 for the AEM
- $260 Jet Performance Stage II chip.
The exhaust cost me about $300 only because we tried both Dual and Single set ups..
My exhaust shop says it should only cost about $180 for the Single Magna Flow System..
Having the muffler relocated is nice because now I have all the extra room under the back for whatever I may come up with..
Just to give everyone an Idea of the Dual Exhaust setup.. @ 2000 RPM’s it actually lost HP and TQ over stock…
Thanks for the posting and all the great info!! As I am new to doing this sort of work, would you mind posting the part numbers of the AEM and JET products you used? I have looked for but not found parts specifically for the 07 Wranglers or the 3.8L V6 and don't really know what would be safe to purchase.
Much appreciated!!
ID:	169565   Click image for larger version
Name:	02-28-2010 006 - Copy.JPG
Old Dec 6, 2006 | 01:47 PM
  #52
Robar's Avatar
If you place your order from Quadratec.com and you order the wrong part for your vehicle they will notify you and let you know.
ID:	169924   Click image for larger version
ID:	169925   Click image for larger version
ID:	169926   Click image for larger version
ID:	169927   Click image for larger version
Old Dec 6, 2006 | 02:09 PM
  #53
Jeephrog's Avatar
Thank you -- that helps a bunch!
ID:	169955   Click image for larger version
ID:	169956   Click image for larger version
ID:	169959   Click image for larger version
ID:	169965   Click image for larger version
Old Dec 7, 2006 | 08:20 PM
  #54
1BADJK's Avatar
Here is the Dyno print out .. The bottom 2 curves are stock and the top 2 are modified.. Hope its clear enough to read..
Edited--- Please keep in mind these numbers are off. Please read my first post in this thread..
ID:	182032   Click image for larger version
ID:	182033   Click image for larger version
ID:	182034   Click image for larger version
ID:	182035   Click image for larger version
ID:	182037   Click image for larger version
ID:	182038   Click image for larger version
ID:	182039   Click image for larger version
ID:	182040   Click image for larger version
ID:	182042   Click image for larger version
ID:	182043   Click image for larger version
ID:	182044   Click image for larger version
ID:	182045   Click image for larger version
Old Dec 8, 2006 | 04:41 AM
  #55
jeffj78's Avatar
Those are some impressive numbers. I'm glad to see that the JK actually responds to bolt-ons a lot better than the TJ's did...
ID:	186906   Click image for larger version
ID:	186907   Click image for larger version
ID:	216539   Click image for larger version
ID:	221103   Click image for larger version
ID:	221105   Click image for larger version
ID:	226844   Click image for larger version
ID:	226845   Click image for larger version
ID:	226846   Click image for larger version
ID:	232520   Click image for larger version
ID:	232521   Click image for larger version
ID:	232522   Click image for larger version
ID:	232523   Click image for larger version
ID:	232539   Click image for larger version
ID:	232540   Click image for larger version
ID:	232541   Click image for larger version
ID:	232542   Click image for larger version
ID:	238527   Click image for larger version
ID:	427457   Click image for larger version
Old Dec 8, 2006 | 01:37 PM
  #56
joss097's Avatar
Very good, torque number are great and there is an improvement on the lower part of the curve. Are those number corrected ones. Stock, it should have 202hp and 237lb/ft , your stock number seems very close to spec? Thanks
ID:	187523   Click image for larger version
Old Dec 8, 2006 | 03:29 PM
  #57
ericdewayne's Avatar
Hey thanks again for doing all this work for everybody. Its good stuff that we can all use. If I woulda known the single exhaust would give better numbers cause the 3.8 likes the backpressure i would have gone with one. Oh well, the duals look badass. lol
ID:	188739   Click image for larger version
ID:	188740   Click image for larger version
ID:	188742   Click image for larger version
ID:	188743   Click image for larger version
ID:	188745   Click image for larger version
ID:	188746   Click image for larger version
ID:	188747   Click image for larger version
ID:	188748   Click image for larger version
ID:	188750   Click image for larger version
ID:	188751   Click image for larger version
ID:	188752   Click image for larger version
ID:	188753   Click image for larger version
ID:	188755   Click image for larger version
ID:	188756   Click image for larger version
ID:	188757   Click image for larger version
ID:	188758   Click image for larger version
ID:	188760   Click image for larger version
ID:	188762   Click image for larger version
ID:	188763   Click image for larger version
ID:	188764   Click image for larger version
ID:	188766   Click image for larger version
ID:	188767   Click image for larger version
ID:	188768   Click image for larger version
ID:	188769   Click image for larger version
ID:	188771   Click image for larger version
ID:	188772   Click image for larger version
Old Dec 8, 2006 | 05:16 PM
  #58
1BADJK's Avatar
I agree the duals looked very BadA$$.... And sounded Awesome.... but oh well.
ID:	189646   Click image for larger version
ID:	189647   Click image for larger version
ID:	189648   Click image for larger version
ID:	189649   Click image for larger version
ID:	189651   Click image for larger version
ID:	189652   Click image for larger version
ID:	189653   Click image for larger version
Old Dec 8, 2006 | 05:36 PM
  #59
AZCA jeeper's Avatar
Yeah they do!!!
Love that look
Old Dec 8, 2006 | 05:42 PM
  #60
tolh13's Avatar
thanks for the numbers and all the work you have inspired me.magna flow on CAI on order and maybe stage 2 for x-mas
ID:	189697   Click image for larger version
ID:	189698   Click image for larger version
ID:	189699   Click image for larger version
ID:	189700   Click image for larger version
ID:	189702   Click image for larger version
ID:	189703   Click image for larger version
ID:	189704   Click image for larger version
ID:	189705   Click image for larger version
ID:	189708   Click image for larger version
