Stock AirBox, Water Spray Shield Redux
Old Nov 10, 2008 | 05:43 PM
  #21
Roxster's Avatar
Originally Posted by rnjstel
As far as the fan, you guys do realize it is a a fan on engine coolant temperature switch and does not run 100% of the time anyway.
It only runs when the coolant reaches around 210F then turns off around 180F or so. Or, when the A/C clutch is pulled in.
I'm not sure that's true. I thought the fan went on when you go into 4-Low, as well. I may be mistaken.
In any event, nice work. I believe that shroud that snowbdr88 shows is a factory piece meant for the diesel version of the JK. I assume there's no problem with restricting air flow with either approach.
Old Nov 10, 2008 | 06:14 PM
  #22
Frozenman's Avatar
AHHHHH Put a switch on the fan anyway, Cause when you're splashing around in the water, a healthy splash or a submerged fan will stall the fan motor. I don't know how long the fan can be stalled for before it becomes toast.
Old Nov 11, 2008 | 07:10 AM
  #23
mudy 07 rubicon's Avatar
ive seen this in action and it works GREAT!!!
Old Nov 11, 2008 | 07:23 AM
  #24
RedneckJeep's Avatar
The fan will be toast whether it's running or not. Electric motors and water ain't the best of friends.
Old Nov 12, 2008 | 01:59 PM
  #25
justinstoffregen's Avatar
Originally Posted by 07armygreen
I think I would be more worried about this mod starving my engine of air than I am the occasional splash.
YOU GUYS are having trouble with spray??? These pics are what my Jeep LOVES...Ha...y'all must be hitting some hard-core water, I would just get a snorkel if it's that bad.
Man, that looks REALLY cool...but you're asking for it.
Old Nov 12, 2008 | 06:03 PM
  #26
mobotix's Avatar
I think I may and try this out as my homemade CAI would definitely benefit from less exposure to water.
