Stock Infinity Amplifier Amp Install
Old Apr 15, 2008 | 02:32 AM
  #41
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
I've got a new twist. Currently I'm running an after market HU with the stock speakers. I've had to disconnect my Sub. I was thinking that I'd just buy a new amp for the sub, but this thread has me thinking (not usually a good idea). Is there any way to have the factory Infinity amp power the sub?
Old Apr 15, 2008 | 05:02 AM
  #42
JulietKilo's Avatar
Thanks for checking into my thread. I think an aftermarket subwoofer and amplifier is in order. The box is definately stout enough. The amount of sound you get from the stock subwoofer is weak. I am very happy with my JL Audio setup. https://www.jk-forum.com/forums/jk-write-ups-39/replaced-stock-sub-jl-audio-amp-31200/ Check it out. Its actually pretty cheap and sounds awesome!
Old Apr 15, 2008 | 07:27 AM
  #43
Woods's Avatar
JeepSWAG
Originally Posted by JulietKilo
Thanks for checking into my thread. I think an aftermarket subwoofer and amplifier is in order. The box is definately stout enough. The amount of sound you get from the stock subwoofer is weak. I am very happy with my JL Audio setup. https://www.jk-forum.com/forums/showthread.php?t=31200 Check it out. Its actually pretty cheap and sounds awesome!
I like the idea of the factory amp, because I don't want to have a sub in the cabin area. The amps that will fit in the factory location, are very expensive. I'd dig on having your setup, but I'm just looking for a way to use what I have.
Is there any way to use the factory amp with an aftermarket HU?
Old Apr 15, 2008 | 09:25 AM
  #44
JulietKilo's Avatar
Absolutely, you would need to use the wiring diagram on the main page of my other post in the write up section, https://www.jk-forum.com/forums/showthread.php?t=31200 Wire it so that the rear of your new HU is going to the amp as the original was using the stock wiring. Then all your speakers are ran the same using the stock wirning harness from the amp.
If you bought the amp after you bought the Jeep then you have some work cut out for you. Seeing as how you are a pioneer of Jeep parts, you probably could do it. You will need to obtain the factory harnesses.
Old Apr 15, 2008 | 09:33 AM
  #45
Squad2man's Avatar
Maybe you already answered this but I have to ask anyway. How hard would it be to add the Infinity amp, speakers and sub to a non Infinity Hu. Any help would be great. Looking to get some more sound out of the Jeep.
Old Apr 15, 2008 | 09:35 AM
  #46
Woods's Avatar
JeepSWAG
Woo hoo, new project for the weekend.
I didn't buy the amp, it came with my JK. This should be a breeze.
Thanks for the info. Great couple of threads here.
Old Apr 15, 2008 | 02:16 PM
  #47
JulietKilo's Avatar
Pretty difficult, due to the wrining harnesses not being in the non-infinity Jeep. If you could find one it would just be too cost prohibitive to really be worth it. I think the best thing to do it upgrade using aftermarket amps and HU. You will have much better sound and it will be easier to obtain the entire setup. Stock is just too much work without sourcing a complete wire harness.
Old Apr 15, 2008 | 02:35 PM
  #48
JulietKilo's Avatar
No problem, that is what this forum is all about.
Old Apr 15, 2008 | 03:20 PM
  #49
Squad2man's Avatar
Is the wiring harness available somewhere to buy? You are extremely helpful, thanks for doing all the research you have done.
Old Apr 15, 2008 | 06:14 PM
  #50
JulietKilo's Avatar
It seems these days that Mopar is sourcing all things for the Jeeps these days. If you could get a part number you might be able to order it from a dealer. You can order wiring harnesses for the axle lockers, sway bar disconnects, etc... why not be able to order the stock harness. In a few more years you could find one in a junk yard after more are wrecked. Good luck!
