Tailgate shock project Done!!
Old Jun 4, 2008 | 05:31 PM
  #101
YellowToy's Avatar
Originally Posted by Jamooche
While this is a great mod, it didn't last for me. (see my prior posts in this tread with a link to a gallery of photos for my install). A few weeks ago I noticed the 30lb shock was bending the mount on the inside body part. And a few days ago, the rivet nuts gave out and the shock popped out.
So what does this mean? I think it means that you need to guide the door open at all times and not let it open and bounce on it's own.
What am I going to do? Nothing. I'm gong to leave the shock off and make a clip mount for some sort of rod or stick that I can pull out to prop the door open (like a hood prop) when the need arises.
Just my experience and I thought I would share.
Anyone try a stiff spring? We used to have a door at our camp that had a long spring that was bent when it was closed. When you opened the door the spring would straighten & act like a prop. You'd then have to bend the spring in the middle with your finger to make it close again.
Old Jun 4, 2008 | 07:28 PM
  #102
HG07JKRubi's Avatar
I'm noticing the same thing on my install. The shock and mounts are still in place and it works great but I can tell that the inside mount will eventually fail due to the stress on the rivets from opening the gate. There is already some wiggle on that mount. We'll see how it goes but I was concerned about this from the beginning that mounting to sheet metal could eventually be a weak spot of this setup.
Old Jun 4, 2008 | 07:41 PM
  #103
Jamooche's Avatar
Exactly. I may eventually try taking out the rear tail light and bolting it through which would make it much stronger.
Old Jun 5, 2008 | 02:16 PM
  #104
Jamooche's Avatar
Originally Posted by neoxxis
That's why I used these:
They lock inside so they will never come off...
Not like the ones that you "try to pop" like a rivet... They will come off I have no doubt!
10-4.
THanks for the info...I'll try those next time.
Old Jun 12, 2008 | 10:34 AM
  #105
sloppyjoe's Avatar
Thats the super duper Tim the Tool man Taylor door system. I like the idea though just a bit stout. Good tymes JOE>
Old Jul 13, 2008 | 08:45 AM
  #106
sixt7gt350's Avatar
I installed at an angle to give the gas cylinder its prescribed "rod down" orientation and it also gives a cleaner look to the bracket on the door. The only real concern is closing the door on cargo and the loss of a couple inches.
Brackets and strut from West Marine.
Stainless attaching hardware from Menards.
I installed the door bracket in about 1 inch from its full extended position.
Old Jul 13, 2008 | 10:02 AM
  #107
cmpmacchia's Avatar
Looks good! I don't like the idea of cutting into the rear door though.....that kind of freaks me out!
Old Jul 14, 2008 | 02:44 AM
  #108
Voodoo's Avatar
This is why I like Brett's kit.
The auminium bar distributes the force on a large surface. Mine is rock-solid...
Old Jul 14, 2008 | 09:50 AM
  #109
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
Hey bud,
I've got a proposal for you. I'd like to see the folks get a review of my kit, as a comparison to others. If you're interested in posting up a review here, I'll send you one of my kits at half price ($35). And if you don't like it, then send it back for a refund. Be forewarned, this kit is much more work to install. But I think you'll be happy with it.
If your just over it and are not interested, I completely understand. And if that's the case, I'll make the same offer to HG97TJ
And for anybody installing any kit such as this DO NOT rely on the shock as a tailgate stop. The stock hinges are designed to do this. Let them do their job. Also, If I'm parked on a grade that's steep toward the passenger side, always hand-hold the tailgate to stop it from flying open.
Thanks for the props, Voodoo.
Old Jul 14, 2008 | 11:03 AM
  #110
Huklbery's Avatar
Default All It Takes Is A Little Care
I installed a 30# strut last winter using pop rivets because the blind-rivet gun I ordered hadn't arrived in time to install the parts before I had to head out on a lengthy road trip. I've taken care to restrain the tailgate on opening and the brackets are just as snug now as they were four or five months ago. If and when the pop rivets fail, I'll drill them out and install the beefier rivets, but the point is, regardless of the fasteners or hardware, it'll always be necessary to ease out the tailgate. Small price to pay for terrific modification.
