Water Pump Replacement
I have 107k miles on my '07 - this thread makes me want to go check my water pump! I have also had a mystery puddle under the jeep but my coolant level has been good all along. I think I topped it off once a couple of months ago.
I will have to keep a closer eye out. My JK is getting to the point that some maintenance is necessary!
Did anyone change the timing belt? How do you know what tension to put back on it?
Well I just finished replacing mine 20 minutes ago... Filled it and now letting it run for a bit... I'm chasing an over heating problem and I already replaced the bad fan motor and assembly, thermostat and radiator cap. Nothing was visibly wrong with my water pump but I figured it was cheap and there aren't that many parts that work with the cooling system... My fan runs full tilt CONSTANTLY and it over heats... Especially with the ac on... Hoping this helps but it's starting to get hot again...
Sent from my iPhone using Tapatalk 2
