Last Frontier If you live in Alaska and would like to meet some of the great JK-Forum members near to you and/or discuss upcoming trail events, this is the forum for you.
Winterization Planning Help...
Old Mar 4, 2011 | 09:06 AM
Heavy_D's Avatar
Originally Posted by CamTom12
Ok, so here's our shopping list:
- Block Heater (Mopar Part No: 82210506) (We'll flush and remix antifreeze to 70/30 during this install)
- 250w Oil Pan Heater (I was going to go with Wolverine unless ya'll have had a lot of issues with them)
- 125w Trans Pan Heater (Wolverine also)
- Deltran Battery Tender hard mounted
Now I guess there's extension cords with multiple female and single male ends I could look for or I had thought about getting a 3-Terminal block and using that to bring all the cords together.
Thoughts?
I was at Waiwright from '96-'99 and this is basically what I did except the oil pan is over kill. I did like AK4Dave and just siliconed a small pad to the oil pan. Also, I did not use the battery tender, they make pads similar to the ones for the pans and you can just set it in the tray under the battery (or use a battery blanket if you would rather. This worked fine for all my vehicles and plan on doing the same to my Jeep this summer since I will be going back at the end of the year after winter has already started.
BTW, what unit are you going to? Maybe we can link up once I get there.
