OK bs
Old Feb 6, 2011 | 02:15 PM
  #1361
u-joint's Avatar
Originally Posted by interceptor_1972
I have a feeling the price of those stock diffs was included somewhere in the Base MSRP of the Jeep . If I've learnt something being in the automotive sales industry for over 10 years now, it's this - Ain't nothing FREE .
They too were free, and thats my story and I'm sticking to it
That's awesome that the gears look ok. Make sure you get a can of brake cleaner and spray the gears and insides of the diff out good and get some shop towel or a clean rag and dry it good to make sure that no foreign objects or dirt is left behind.
It is going to be a week before we work on it... any ideas on how I should handle it in the mean-time? Is it ok to just leave the gears exposed (albeit in my garage)? Or should I just put the cover back on, even though there is no oil in there?
When I go to change the seal I'll have to (apparently) remove the carrier. I will be sure to clean everything exceptional well then with brake cleaner.
Take it it's the front diff that's leaking? Where exactly is it leaking from again? Is it where the driveshaft flange is? Or is it leaking from the axle shaft side?
Its leaking at the far end of the axle tub, by the driver's tire.
Old Feb 6, 2011 | 02:16 PM
  #1362
u-joint's Avatar
Originally Posted by TORN
I would use some anti-seize or pipe dope when you put plug back.
Humm... this is going to show my ignorance, but I've never heard of either of those before
Old Feb 6, 2011 | 02:21 PM
  #1363
TORN's Avatar
I would just put the cover on with a few bolts just to be safe. When you overfill dif , pressure will push oil out of seals and/or vent tube.
Old Feb 6, 2011 | 02:24 PM
  #1364
interceptor_1972's Avatar
...any ideas on how I should handle it in the mean-time? Is it ok to just leave the gears exposed (albeit in my garage)? Or should I just put the cover back on, even though there is no oil in there?...
...Its leaking at the far end of the axle tub, by the driver's tire.
I'd put the cover back on and just hand tighten the bolts. No need to torque them down at this time. With the diff fluid emptied, it shouldn't leak out the axle tub anymore. Just make sure it doesn't dry up. Since it'll be for just a while, you'll be fine. Just make sure there isn't any water moisture in there - don't want any rust build up inside
That's where I figured it's leaking from. Just make sure you got a catch pan down to collect whatever little might drip out - keep it off your garage floor .
Anti seize will keep the threads from locking up (kinda like the reverse of locktite). Pipe dope - never heard that before, but wonder if it's plumbers tape?
Old Feb 6, 2011 | 02:26 PM
  #1365
Midgear's Avatar
starting to miss summer
Old Feb 6, 2011 | 02:27 PM
  #1366
It's just around the bend... trust me
Old Feb 6, 2011 | 02:28 PM
  #1367
TORN's Avatar
Anti-seize comes in a tube at auto parts store and keeps bolts and nuts from seizing. Pipe dope comes in a tube in plumbing section and is like teflon tape but in paste form.
Old Feb 6, 2011 | 02:29 PM
  #1368
...Pipe dope comes in a tube in plumbing section and is like teflon tape but in paste form.
That's what I thought it meant - now I know another name for plumber's tape
Old Feb 6, 2011 | 02:45 PM
  #1369
SilverJK12's Avatar
I am beefing up my d30 and 35s now but looking into 37s soon.
Old Feb 6, 2011 | 02:47 PM
  #1370
SilverJK12's Avatar
What dif covers do you have? I have the Rockcrushers and they just get very tight with the heat generated. Go find a Giant Allen wrench to get it off. You can also use a grade 8 bolt head maybe. I twisted a grade 8 off like it was nothing though. I finally took the cover to the vice and heated around the plug with a torch.
I have some diff covers from king offroad in BA . It twists off with your hand so easy to get off and stays there too when tightened. Cost $99 for locals
