OK bs
Old Jan 14, 2011 | 03:31 AM
  #571
Mark Doiron's Avatar
Originally Posted by interceptor_1972
That might do the job... But I think that also requires you to take out the factory mount. Might see what other options there are... maybe shim it?
Jeff and I are using these ...
Rock Krawler Rear Coil Spring Correction Wedges
Easy install, but not certain how well they will work with the different pinion angle required for your new driveshaft. You might check with Jeff.
Old Jan 14, 2011 | 03:35 AM
  #572
Originally Posted by PainKiller
yes, the drive shafts have u-joints
What I'm trying to figure out is they have what appears to be a conventional u-joint at one end (the T-case, BTW), and a CV joint at the other (the differential). Since a conventional u-joint causes the driveshaft to vary in velocity as it makes one revolution (this is caused by the moving back and forth of the u-joint as it revolves), and a CV joint is designed specifically to NOT do that (hence the name), how is is that these two seemingly incompatible pieces of hardware can be made to play nice on one driveshaft? What am I missing?
Old Jan 14, 2011 | 08:05 AM
  #573
interceptor_1972's Avatar
Do those go under the rear coils I presume? If the pinion angle changed, wouldn't the wedge just slide out?
Old Jan 14, 2011 | 08:14 AM
  #574
Well, on my Jeep they are held in place by the spring keeper that was provided with the TF coil lift. Basically that is a fender washer large enough to trap the bottom coil of the spring, with a bolt and nut that hold that onto the spring perch. TF provides a special tool with their kit that makes it a snap to get the nut properly placed under the existing hole in the spring perch (you're reaching over the top of the axle and under the spring perch). I kept my tool, but know folks have installed similar spring keepers using just basic handtools--maybe bent needle nose pliers. Anyway, if you get a new TF kit, you should have everything to do the work. If someone else does the install, make sure to get that tool from them.
Old Jan 14, 2011 | 08:28 AM
  #575
Well, on my Jeep they are held in place by the spring keeper that was provided with the TF coil lift...
Hmmm... I might have to take a look to see how it is with the RC coil setup that I have right now. I do intend to switch over to the TF coils soon enough, so if the RC setup doesn't have something similar, then I might just wait it out till I switch to the TF. The other option is the JKS Spring relocators.
Old Jan 14, 2011 | 08:47 AM
  #576
... I might just wait it out till I switch to the TF. .....
It is literally a fender washer, nut and bolt. Maybe a lock washer, too. I expect you could cobble something together at a hardware store.
Old Jan 14, 2011 | 11:25 AM
  #577
r_stramel's Avatar
It was nice meeting you today Tony. Thanks for the great deal! Now I just wish those ball joints would hurry up and arrive so I can put those new items to use... well maybe not the lift, I dont feel like getting stuck just to try it lol. Interceptor, if the guy with dibs falls through let me know I'd be interested!
Old Jan 14, 2011 | 12:42 PM
  #578
Originally Posted by r_stramel
...Interceptor, if the guy with dibs falls through let me know I'd be interested!
I will
Old Jan 14, 2011 | 06:10 PM
  #579
PainKiller's Avatar
I have been searching the web trying to figure that one out also ( no answers yet). I can't figure out how that set up works the way it does some engineer has way to much time on their hands
Old Jan 14, 2011 | 06:26 PM
  #580
Or some engineer had one extra U Joint and said - "Ah ha, I know what I can do with this"
