15" Wheels???
Old Aug 14, 2013 | 03:08 PM
newjkman's Avatar
Default 15" Wheels???
I have a 2013 2D with factory 17' aluminum rims. I am thinking about going with 35x12.50 15 Kumho MT KL71 tires with 15x8 Black Rock aluminum rims. I have been told the rims I am looking at will fit with out a problem. Do you see any reason to go 16, 17, or larger?
Old Aug 14, 2013 | 03:29 PM
JohnnyQuik's Avatar
A lot of people run 15" wheels. I've got a barely used set with 35's for sale right now as a matter of fact. The only rear issues are if you want to run certain aftermarket tie rods or big brake kits that need more clearance. A lot of 15" wheels clear the stock brake calipers just fine and the tires average $100 cheaper than some larger wheel sizes.
Old Aug 14, 2013 | 03:36 PM
AaronJK's Avatar
I love my 15's. American racing ar 23. I have the synergy tie rod and drag link. Only issue with the tie rod is when it rotates all the way up, but that only happened when I had it resting on a rock I was stuck on. I think you get less wheel/tire damage on 15's. I'll go back to a 17 when I move up to 37's or larger.
Sent using my SuperSmartThinky Phone
Old Aug 14, 2013 | 03:40 PM
karls's Avatar
15's here and no issues, CHEAP tires!!
Call up discount tire direct, they'll set you up with some 15's that fit with no issues.
Sent from my DROID4 using Tapatalk 4
Old Aug 14, 2013 | 03:55 PM
mistasparkl's Avatar
I like 15"-16" wheels, but traded in mine for 17"s. Hardly any 37" inch tire choices for 16s. Also i didn't want to deal with clearance problems when upgrading Tie rod ends, or brakes w/ a 15" wheel.
Old Aug 14, 2013 | 03:57 PM
kh202's Avatar
Love the 15's! IMO looks the way an offroad wheel/ tire setup should look! To each their own tho
Old Aug 14, 2013 | 04:46 PM
RND's Avatar
RND
...pass...
Old Aug 14, 2013 | 04:48 PM
karls's Avatar
15's and 44's......the way it should be-
Old Aug 14, 2013 | 04:56 PM
2011MMJK's Avatar
I went with 16" because I didn't do my research on here first wish I had went went 15" most tire places say 15" will not work. Tire price is the main reasin for me but I have no plans of other suspension or brake upgrades. But 16" still saved me $150 per wheel and tire combo over 17".
Old Aug 14, 2013 | 04:59 PM
revvinkevin's Avatar
I'm happy with my 15s. No problems with clearance for me.
