2.5 on 37's
Old Dec 15, 2011 | 04:35 PM
hsacks820's Avatar
Default 2.5 on 37's
Hi guys!
i have a TF 2.5 coil lift and PSC bumpers and flat flares.... whats mods would i have to do to run 37's on this setup??
Old Dec 15, 2011 | 04:40 PM
Jreyes24's Avatar
Probly some trimming I have the same lift with flat fender flares but with 35s and they seem to be the perfect size
Biginboca's Avatar
Originally Posted by hsacks820
Hi guys!
Planman has the answers you seek, but off the top of my head
1" body lift
3.5" total extended rear bumpstops
2.5" total extended front bumpstops
But look for one of planmans threads on running 37's for the best info.
Old Dec 15, 2011 | 04:41 PM
jtjk's Avatar
1" body lift
x2. this is what im running, works great. as he says check planmans threads, he is the king of little lift gint tires.
Old Dec 15, 2011 | 05:47 PM
20JK10's Avatar
You will have to trim the pinch seem in the rear fender well.
Old Dec 15, 2011 | 05:49 PM
kgw350's Avatar
On my 09 i ran 37s on a 2.5" procomp with 3/4 spacers in the front 2.5" bumpstops front and rear. No rear swaybar front disco. Folded the hole rear pinch seam over cut 2.5" off the rubi rail and cut my factory flares. The only rubbing i had was the front tire on full turn on the the lower control arm and the drive shaft on the tranny it was an auto.
ID:	250494Click image for larger version
Here is my 2012 with 37s on a 2.5" Rock Krawler and a 1.25 body lift to eliminate the trimming of the rear pinch seam i had to do on my other jk cut 2.5" off rubi rail and factory cut flares. No rubbing
ID:	250496Click image for larger version
I got a lot of info from planmans thread.
Old Dec 15, 2011 | 06:02 PM
CodyB4C's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=250494"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=250495"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=250496"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=250497"/>
Did you have to extend your bump stops?
Old Dec 15, 2011 | 06:40 PM
currdog's Avatar
you can roll with you current set-up as is. You'll get some rubbing at full stuff but if you don't articulate much it won't be an issue. With my 2.5" bb, I cut the pinch seam and chopped the front bumper. will be working on the fender chop over xmas.
Old Dec 15, 2011 | 07:25 PM
highoctane's Avatar
I run 37s on my Teraflex 3" with flat fenders, trimmed pinch seam, and since I have longarms I was able to adjust the axles so nothing really contacts anywhere. I do get some tire run on the upper spring perches and frame rails up front, but I have 4.25" bs wheels, so some 3.5" bs wheels or some wheel spacers would fix that.
Old Dec 15, 2011 | 07:45 PM
jtjk's Avatar
dont forget to consider gears as well. with 37's 5:13 for manual and 5:38's seem to be a good idea to keep drivability on hills.
