2.5" inch lifts - difference in flex
Real life can be like that. I think the best move a person can make is do the no-spring suspension travel test on the garage floor and then decide what should work best.
Did you need to use limit straps? Did you compare total suspension travel with different shocks on the 2" springs? Not trying to be overly confrontational, just genuinely interested in how it actually worked for you.
i used coil retainers front and rear, bottom and top, but ideally, limit straps would have been more ideal. to match the shocks i switched from linear coils to dual rate and since then i have successfully been able to remove the coil retainers.
