which 2.5 kit do i need
Old Mar 12, 2011 | 08:00 AM
jstrong394's Avatar
Default which 2.5 kit do i need
I have a 2dr jk and ordered 35's and rockstars. Which 2.5 teraflex do I need this jeep isn't going off road its my wifes and its what she wanteed
Old Mar 12, 2011 | 08:17 AM
Joisey's Avatar
2.5 coil w/ shocks. Its a little more than the buget boost, but it will ride nicer and its complete
Old Mar 12, 2011 | 08:20 AM
GON WHLN's Avatar
If it has to be TF and not leaving the pavement then save some $ and get the 2.5 BB with shock extensions. Hopefully you have rockstars ordered with 4.5 or more backspacing. Then if needed trim your fenders (probably won't need to since it won't be flexing).
2dr may require rock rail and pinch seem trim.
Old Mar 12, 2011 | 02:36 PM
currdog's Avatar
The puck budget boost with extensions will meet her needs just fine. Coils are overkill for your stated purpose. bb cheaper and faster to install.
Old Mar 12, 2011 | 02:41 PM
sringer's Avatar
I have 35's with a 2.5 bb from teraflex. It fits just fine :-)
ID:	136823   Click image for larger version
ID:	136826   Click image for larger version
Old Mar 13, 2011 | 07:25 AM
jstrong394's Avatar
Is it possible to order the rockstars in 4.5 backspacing? Only ones I found are 5
Old Mar 13, 2011 | 07:39 AM
GreenJK07's Avatar
Go with a bb. Really any company works for what you are trying to do.
Old Mar 13, 2011 | 08:02 AM
jstrong394's Avatar
Old Mar 13, 2011 | 05:28 PM
dougk's Avatar
I am replacing the BB with the TF coil with shocks. The BB on the Jeep we just purchased was not installed correctly, who know what damage has been done to the coils and shocks, during the week my wife uses the Jeep to drive the children to school and I dont want to risk an issue due to the incorrect installation, the Jeep has 66k miles on the original shocks making it prime to replace the shocks.
My situation was such that the 2.5 coil with shocks was the right choice, you just need to find which options best fits your needs....
Doug
Old Mar 13, 2011 | 10:20 PM
troyboy's Avatar
You would be fine with a 5" bs since stock are 6.25". That's 1.25" farther out. You may rub still on a tight turn. If you do I bet all you need is one washer under the turn stops to fix that.
