View Poll Results: Which Version of the TF Lift?
TF 2.5" Budget Boost
15
12.50%
TF 2.5" Coil Boost w/ Extenders
33
27.50%
TF 2.5" Coil Boost w/ Shocks
70
58.33%
Other - Please Specify - Must be max of 2.5"
2
1.67%
Voters: 120. You may not vote on this poll
Which 2.5" TeraFlex Kit?
Even if you don't do much off roading I would still go with the TF coil kit if you plan to get metal bumpers or anything else heavy up front. . The stock rubi coils really really sag under any weight. When I installed JUST the ARB bumper I had 1.5" of clearance from the top of the stock tire and the fender flare. I was afraid to add the winch because I thought I would rub just going over a pothole or up a driveway.
I am going the same route...I plan on getting a 2.5" lift (maybe within the next 3-6 mos). Allthough I wont be doing any extreme offroading, I plan on getting the lift w/shocks...It may be a little more expensive, but to me it will be $$$$ well spent just in case my offroading changes (better to have it and not need it, then to need it and not have it
). I have been tempted many times to get a BB kit just so I can run 35's & make the JK look more aggressive w/the lifted stance, but I held off. It may take some time to save the $$$, but in the end you will be happy. As for the stock parts you could probably sell them to offset the cost if you dont plan on keeping them.....Best of luck on your choice....A difficlut one when pulling the trigger in getting your first lift....
I took the liberty of sending e-mails to Dave at NorthRidge (who rocks!) and Joe at TeraFlex. Here's thier responses.
and from Joe
Seems like based on the vendors I should most def go the extension route.
Originally Posted by Dave @ NorthRidge
Since you have a rubi and your shocks are pretty good I would go with the 2.5" kit with shock extensions. That is the most popular kit we have to be honest.
Originally Posted by Joe @ TeraFlex
The best kit for you will be the #1352000 coil kit with shock extentions. This allows you to reuse your Rubicons shocks, which are a great stock shock. Our shocks will ride about the same but would allow for 2-3" more flex. You'll save some money this way and still get a great ride and a great kit.
If you don't get the coils, you will always wonder just how much better your jeep would have done with the coils instead of the factory springs and a piece of plastic. I have not read one bad thing about that coil kit.
I have the coil w/shocks but I have an X. If you are going to go offroad I would recommend getting the shocks for the articulation. If you are no going to wheel very hard go with the extensions. Either way you will be getting a great kit.
