2.5inch spacers
Old Sep 13, 2008 | 03:12 PM
JK-Q8's Avatar
Default 2.5inch spacers
I tried the search but couldnt get it clear. on a 2 door i know its maximum to put a 3inch lift, but then you put extra wear on the driveshaft. i wanted to ask what if i put 2.5inch spacers, will i have trouble with the drive shaft? or will i put too much strain on it?
Old Sep 13, 2008 | 03:13 PM
Ryno's Avatar
There are lots of people on here running 2.5" Teraflex BBs with no driveshaft problems.
Old Sep 13, 2008 | 03:15 PM
JK-Q8's Avatar
thanx for the super fast reply. IS that they dont have it too long? with a 2.5inch is there any extra wear on the driveshaft?
Old Sep 13, 2008 | 03:26 PM
Ryno's Avatar
With normal street use, probably not. If you have an automatic, there's definitely a greater potential for damage off-road, as your front driveshaft can contact your transmission skid plate and cause damage. With a 6-speed it's not an issue.
Most of the rental Jeeps in Moab have logged thousands of problem-free off-road miles with 2.5" BBs and stock driveshafts. Those things get abused more in 5,000 miles than most Jeeps will get abused in their lifetime.
I think you will be fine. Just be aware that you are slightly increasing the risk of driveshaft failure, but it's not something you should worry about.
Old Sep 13, 2008 | 03:34 PM
JK-Q8's Avatar
Perfect thats exactly what i needed to hear. do you about how much the spacers cost? thanx.
Old Sep 13, 2008 | 03:44 PM
Ryno's Avatar
$264.95 from Northridge4x4 for the Teraflex 2.5" BB with shock adapters. I don't know how much shipping to Kuwait would cost. Send David a PM and see what he can do for you.
http://northridge4x4.com/proddetail....d=TF-001355210
Old Sep 13, 2008 | 03:50 PM
JK-Q8's Avatar
thanx david helps alot. is there anything simpler for 2.5inch?
smack2020's Avatar
I have had a 2.5 BB for over a year and no problems. I wheel fairly hard, but I only have 13000 miles on Jeep. I also have a 1 inch body lift and 35's and I love the look and performance.
Old Sep 13, 2008 | 04:00 PM
JK-Q8's Avatar
thanx, but is there something simpler than a bb, like just spacers?
Old Sep 13, 2008 | 04:25 PM
Ryno's Avatar
Are you lifting mainly to increase ground clearance, or to be able to fit larger tires? Or both?
