2012 ARB Compressor Mount / other on-board air options
Old Dec 12, 2011 | 10:26 AM
River Hill's Avatar
Originally Posted by Nwapache
I'd be happy with it for airing up every tire on a tractor trailer rig! this thing blows harder than a politician. I can go from 10 to 35 lbs on all four tires in under five minutes. You definitely get what you pay for.
Any chance you can post a picture, as I am thinking of this same setup for my 2012?
Old Dec 12, 2011 | 10:59 AM
Vinson Clark's Avatar
I had a arb compressor installed on my 2011 before i traded it in. I took it all off and ordered the new evo bracket for the 12 and rugged ridge a pillar switch pod from david at northridge 4x4. As soon as it comes in i will post up some install pictures for you.
Old Dec 12, 2011 | 11:32 AM
MVines's Avatar
Has RR released the switch pod for the 2012. There where a few posts stating it would not fit on a 2012???? I hope the have made changes, becuase I need one too.
Old Dec 12, 2011 | 11:35 AM
Im assuming it will. If not i will be the test dummy and let you no im pretty sure it fits the 11 and the interior is the same in the 11 and 12.
Old Dec 12, 2011 | 01:31 PM
River Hill's Avatar
I see the EVO bracket won't hold the twin on the 2012. Do you have the large or small compressor and how long does it take to air up your tires. I was looking at the twin hoping to use the EVO bracket, but I guess not.
Old Dec 12, 2011 | 02:31 PM
I have the medium size compressor its not the twin but not the smallest. Its the one that comes with a tire inflation kit. I took my stock 29in tire on my 2011 and aired it down to 5psi and back up to 32psi in about 1 min it works great i will be using this compressor with my 37s as well.
Old Dec 17, 2011 | 05:52 PM
River Hill's Avatar
Originally Posted by Bonker
Any ideas on mounting options for the ARB twin?
Has anyone come up with a way to mount the ARB Twin in the engine compartment of a 2012?
Old Dec 17, 2011 | 06:24 PM
gundybears's Avatar
Or in an '07 2 door in any place?
Old Mar 25, 2013 | 02:47 PM
police528's Avatar
Default pictures
I spent a week trying to figure it out when I got mine. I opted to mount it under the passenger seat. It stays clean and dry, the wiring loom makes it to the battery easy, and my gf gets a cheap thrill when it cycles
can you send some pictures of the install? i just bought one an cant seem to figure out where to mount it.
Old Mar 25, 2013 | 04:21 PM
Cool Danish's Avatar
I just finished installing my ARB twin compressor. I created my own brackets and used existing holes in the seat brackets. It was a really tight fit and I had to angle the compressor a little to clear seat wires (ABS sensors & seat heater). If you notice I also notched the one bracket to clear a bump in the transmission tunnel. See pics below (before I painted the bracket black):
ID:	438471Click image for larger version
ID:	438472Click image for larger version
ID:	438473Click image for larger version
ID:	438474Click image for larger version
