2drs on 40s
Old Jan 30, 2013 | 03:12 PM
RJtx's Avatar
Default 2drs on 40s
I've searched and searched and didn't really pull much off of here or other sites reguarding the details of different 2 doors and 40" tires. Im winding down another tour in the middle east and I want to lift my jeep. Its a 08 JK X model 2 dr with 34,000 miles on it (tells you how many times I been gone? lol) Auto tranny and 3.73 gears. Im currently running 315 duratracs, 2.5 budget boost, 1.25 BL (which I am ditching) and it handles pretty good where I want to go but damnit I want to go bigger I believe I earned it lol. I mainly drive on the road with the occasional off road trips in the Olympic forest. I was thinking 37s but I like the look of some of the ones I seen on 40s. I wheel lightly and RARELY floor it. So im gonna run this by ya'll and see what you think.
40" Goodyear Mts
Front sleeved, gusseted, trussed, locked (ARB), 30 spline RCV shafts, 5.38 gears
rear trussed (maybe), locked (ARB), 35 spline chormoly shafts, 5.38 gears
Front and rear driveshafts
Proably keep the 1.5" wheel spacers
that's the axle side of it and I believe it would hold up to my use but that why I am here to talk to people with better experience. Now beyond that as to what lift and rims I want IDK I'll proably stick with rough country either a 4" or 6" cause of price and I don't really need flex and have had good experiances with them in the past. also could I get pictures of 2drs on 40s with various life hights? I don't want to cut more than just the pinch points and Im trying not to rub. any help would be greatly appreciated. And If I somehow missed a tread will all this info on the lifts and the 2 doors on 40s link me to it so I can read up.
Old Jan 30, 2013 | 03:15 PM
Tonka_yellow's Avatar
5.38s won't fit in a Dana 30 I believe. You should look into a Dana 44 from a rubicon or dynatrac 44 or teraflex 44... Look up plannman. He's running 40s on a two door. You could get a 4-6 inch lift from anyone and flat flares to run 40s... Also you will need some type of tire carrier
Old Jan 30, 2013 | 03:23 PM
RJtx's Avatar
how good will the 5.13s turn the 40s? anyone know where I can find a bolt up used D44 housing?
Old Jan 30, 2013 | 04:03 PM
Ryan0260's Avatar
Pretty sluggish. I would go with a D44 with 5.38's
Old Jan 30, 2013 | 04:05 PM
Ryan0260's Avatar
If you plan on hard off roading you might consider a D60
Old Jan 30, 2013 | 06:23 PM
RJtx's Avatar
well im guessing i'll have to go to D44.... what about used Rubi housings? they are about the same as my D30 right? (besides the guts) with the ball joints and calipers and all that swap right over? (i'll put new ball joints of course) were could I get an used axle housing that is a straight up bolt on swap? what years or jeeps did they come from?
Old Jan 30, 2013 | 07:00 PM
Pluke the 2's Avatar
Skip the 44 and go to a 60. Lots of good write ups on this subject. Definitely go with 538s
Old Feb 1, 2013 | 02:47 PM
RJtx's Avatar
Screw it im goin all out. I just found out my fiancé is screwing my neighbor lol... so that being said I still want some left over for an AR15 and 1911 and reloading stuff... im setting my budget at lets say $21,000 (lift, tires, tools, welder, axles, driveshafts, bumpers.) so check my run down and input would be nice... thank you
5.5" Rusty's lift
Bushwacker Flat fenders
Rock Jock Dana 60 Front and rear with 5.38 gears and Detriot Electracs
J.E. REEL 1310 C.V. Heavy Duty Driveshafts
PSC Jeep JK Extreme Duty Cylinder Assist Kit (using my stock box)
40" Goodyear MT/Rs
Currie CURRECTLYNC JK Wrangler heavy duty steering system
GenRight JK Front STEEL Bumper with Boulder Series Stinger
GenRight JK Rear STEEL Tire Carrier
GenRight JK Rear STEEL Bumper
Black Rock Series 942 Type D Matte Black Wheels 17", 5"x5.5" bolt pattern, 4.5" backspacing (axles are 66" wide)
Am I missing anything?
Old Feb 1, 2013 | 03:00 PM
cmurf's Avatar
Much sympathy and empathy about your fiance. Been there. At least you found out before you tied the knot.
Sounds like you are going to wind up with a killer rig. Look At forward to the pics.
Sent from my SPH-L900 using Tapatalk 2
Old Feb 1, 2013 | 03:06 PM
Atch's Avatar
I'd recommend 1350's instead of 1310's
