2wd to 4wd conversion help!
About to start this project on my 07 JKU.
Making a parts list and just trying to double check everything!
1. Front axle with 4.10 gears
2. Front & Rear driveshafts
3. Transfer case
4. 4wd shorter tailshaft
5. Shorter adapter for transmission to T-Case
6. Cross Member tranny mount
7. 4wd shifter
8. 4wd shifter cable
9. Tail housing
10. Tail housing mount
11. Input shaft
12. Tail housing cable bracket
13. Shaft clip
If you've done this or know anything about it let me know if i missing anything! Thanks!
3. Transfer case
7. 4wd shifter
9. Tail housing
11. Input shaft
13. Shaft clip
Sponsoring Manufacturer
Rusty's Off-Road
Rusty's Off-Road
3. Transfer case
7. 4wd shifter
9. Tail housing
11. Input shaft
13. Shaft clip
3. Transfer case
7. 4wd shifter
9. Tail housing
11. Input shaft
13. Shaft clip
# 4 , 9 and 10 take off your list
Here is some pictures of the adapter and adapter mount
The bracket to hold the cable on the adapter
Last edited by jaker t5; 06-02-2013 at 04:18 PM. Reason: No Eddie but still no links allowed
I converted mine and my total cost after upgrades was 1800
